![]() | Home > General (L494) > Anyone hardwired a dashcam in L494? |
0310 Member Since: 28 Jul 2015 Location: A long way NW in the UK Posts: 213 ![]() ![]() |
Has anyone found a UK supply of Micro2 fuses? Searched via the usual suspects but nothing.
There is a spare of each amp in the boot fuse box. I like keeping spare fuses so I ordered 2 of each from forum sponsor duckworthparts. Very reasonable price and arrived in a few days (could have been the following working day but Dan had to order from the supplier). Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Thanks, I will get in touch with Dan. Thought I was going to have to order them from the USA via Amazon.
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
I've hardwired Thinkware in my DS and it was very similar to blackvue install I did in previous RRSs
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 ![]() ![]() |
Just wonder what you guys think of this installation. This is a Road Angel Halo front and rear camera unit professionally installed. I'm happy enough with the front camera installation but the rear camera installation seems a bit untidy. The installer told me that on the L494 there is no space under the interior plastic panel of the tailgate to run the wiring so he had to use sticky pads to secure the wiring on top of the panel. The second point is that obviously I can understand why there has to be a loop of wire to allow for lifting of the tailgate but is there more tidy way of doing it? Lastly what about the position of the camera itself? Could it be offset from the centre line and hidden higher?
That's awful |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 542 ![]() |
If you look earlier in this thread you will see I had exactly the same problem on my 494... The camera location is easily changed and because of the dirty sweep of the rear wiper I offset mine slightly to one side but at the top of the screen certainly neater than yours...
Yes please! |
On the second photo I can see rubber tubes at bottom of pic that I threaded my cable through on DS so it must be possible too |
Thanks I understand that but the installer said that there was no space under the plastic panel to run the wiring to the screen |
On the DS the cables for demist and brake light run in the trim so my cable for camera did too
Be exceptionally careful prising these rubbers off... They are held in place with a extremely brittle clip which if they break you're dead.... The complete boot loom will need to be refitted.... Once inside the tailgate side there is no where to feed the camera wire and the boot is a bonded plastic panel and despite hours off trying to feed coat hangers, cable feeders etc etc I found no where to slide the wire.... In the end I had to cut a corner out of the rubber block out and come back out...not ideal! |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
Just bringing this thread back to the fore, and wondering if anyone has had any success with mounting a rear camera in an L494; my installer came up with the same problem as has been mentioned above (seemingly impossible to get between door trim and outer skin), so how to feed a wire through from one of the two rubber "hoses".
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 ![]() ![]() |
Had the latest Blackvue fitted professionally front and rear in the summer. All looks good and neat – he didn't seem to have any trouble threading the wire through to the boot. When the boot is closed you only see the inch of wire to the connection which would be visible however the cable was run.
