Home > Maintenance & Modifications > Folding mirrors on key
Socast
Hey folks,
I've been trawling the web trying to see if it's possible to make the dream a reality, can an 06 RRS be modified in such a way as to allow the mirrors to un/fold when un/locking the car.
I think the answer is yes, I found a post on here with a link to this:
http://www.fordwiki.co.uk/index.php?title=...Remote_Key
Now the chap was saying it's the same on the RRS as on the Mondeo, now that's all well and good and the instructions are pretty straight forward - however!! It states that there is a harness down hear the drivers feet that you need to splice into, I've not actually looked yet but I'm pretty sure there isn't one on the RRS, my best guess is that you will patch into the BCM.
Nobody would happen to know if it is the BCM you patch into and if so which wires do you need to splice ?
Post #487244 Fri Feb 12 2016 11:07am
TheWojtek
WANT!!!! Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #487274 Fri Feb 12 2016 1:47pm
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
Want
Post #487277 Fri Feb 12 2016 2:14pm
TubaPlayer
This would be great 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #487278 Fri Feb 12 2016 2:52pm
markryan15
United States 2008 Range Rover Sport Supercharged Alaska White
I'd love this!! Please let me know if you find out if this will work or not.
Post #488027 Fri Feb 19 2016 3:39am
SH0X
This mod isnt hard to do with basic thinking you can work it out to tap into the power fold switch and wire to relay which gets power when car it locked eg the wire that activates alarm or others (not indicators as these need to be used when normal driving) the relay then clicks and powers the mirror switch.
Abit of thinking to do but can be done by someone familiar with the fusebox area - if someone knows what you can tap into to get the power from on lock / unlock then the rest will fall into play
I did similar in 2010 on my Audi TT MK1 for welcome / unlock/ lock headlamps mod. If I had more time on my hands or a RRS buddy to work with I could work this out!
Edit. I had a look at my old thread from my tt days ... my initial idea was to take the power from the interior light which comes on when the car is unlocked. I might give this a go when I get time Im sure I can do it.
Post #488327 Sun Feb 21 2016 12:21am
Socast
If you take a feed off the interior lights the mirrors will fold every time you open a door or the boot.
A better idea would be to take a feed from the central locking, however you've then got the problem that when you double click the key to unlock all doors, the mirrors would start to fold and then return. You would also need to add a resister to prevent the car from locking if you fold the mirrors on the internal switch.
I found the original post on the DS3 forum and seemingly someone had doe the mod to their vehicle, but I can't seem to find it now haha.
Post #488929 Thu Feb 25 2016 4:31pm
SH0X
That's true. I had a relay on my tt but can't remember if I fully finished it.
You could press 3 times if coming from the cl perhaps? interior light will be annoying I think I initially had a kill switch fitted but sort of defeats the he purpose if yiu are using a kill switch to disable the feed... might aswell press the fold button !
Post #488976 Fri Feb 26 2016 2:42am
markryan15
I have just found this kit:
https://www.ebay.com/itm/111016438613
Anybody have any idea if it'll work on Range Rovers? I messaged the seller and he said that it should but he has never installed on one, so he can't say for 100% sure.
Post #495664 Wed May 11 2016 2:06pm
Socast
Shocked if it works! looks a little bit cheap and Chinese... Rolling Eyes
At Ł25 though it might be worth a punt.
Post #495668 Wed May 11 2016 2:48pm
markryan15
I'm thinking about giving it a shot, however, I'm not sure how to wire it. I'm not good with wiring things.
Post #495675 Wed May 11 2016 4:42pm
TheWojtek
OK, I just bought exactly the same unit from a local online reseller. I should be getting it on the day after tomorrow, will not fit during the weekend as I have already planned my EAS compressor refurbishment, but I might be able to give it to a shop for fitting next week. Regards etc.,
Wojtek
Post #495693 Wed May 11 2016 8:30pm
markryan15
Awesome. Please let me know how it goes, once you get it installed
Post #495719 Wed May 11 2016 10:47pm
SH0X
Wow great product makes life easier and seems well thought out from the offset.
Defo worth a try but will require some basic wiring skills plus possible removal of door card but that's not hard to do.
They mention tapping into the door lock actuator which is a good place actually as the mirror wire is close to that anyway.
A one way relay would work well if trying to make your own so it stops the mirrors folding unfolding when the acc is on.
Post #500798 Thu Jul 14 2016 12:19pm
