Home > Technical > Suspension Compressor
The Duke
France
Well that's been an interesting few weeks...
I have replaced 2 compressors for the suspension the 1st one OE from Land Rover dealership was kindly fitted by one of the Disco 3 guys, thanks Kris, however it came back with a fault on the exhaust so he refitted the old one as I was heading off to France. Kris returned the new compressor as faulty and they sent a new replacement which I had fitted yesterday but didn't have the tool to do the update. So I took it to DSL in Worksworth Derbyshire and paid the princely sum of £54 for them to update the software and this has also come back with a fault on the exhaust.
Any ideas!!!
Post #487613 Tue Feb 16 2016 11:47am
Paddi
As far as I know your TDV8 would have left the factory with a Hitachi compressor. Presumably the replacement is the AMK which superseded the Hitachi. I had an AMK fitted to mine and although everything worked fine my IID tool consistently found an 'exhaust valve' fault. Luckily an update to the IID tool included the ability to identify the compressor software version and reflash it.
Lo! I discovered the software installed was the Hitachi version. Reflashing to the AMK version eliminated the 'exhaust valve' fault.
Could this be your problem? 2008 MY Java Black TDV8 HSE
Post #487655 Tue Feb 16 2016 6:10pm
The Duke
France
Sadly NO Big Cry
Just tried the install which was quick however the fault now showing up as
C1A36-01 (AF) Exhaust valve - General failure information - general electrical failure
If anyone has any ideas would appreciate feedback
Post #487927 Thu Feb 18 2016 5:46pm
Paddi
That's disappointing then.
C1A3601 was the fault code I was getting. After the re-flash it hasn't reoccurred.
A perhaps daft question - but I'm assuming you cleared the fault and then re-scanned?
Are there any symptoms or are you just getting the fault code?
The workshop manual lists the following possible for this fault code
Exhaust valve, general
electrical failure:
Exhaust valve
disconnected
Exhaust valve harness
wiring short circuit to
ground or high resistance
Exhaust valve failure
Air suspension control
module failure 2008 MY Java Black TDV8 HSE
Post #487932 Thu Feb 18 2016 6:10pm
The Duke
France
Yes, re scanned and the fault is coming up as:-
The suspension light is on, on the dash and can't use suspension control at-all (It's locked) Big Cry Big Cry Big Cry Big Cry Big Cry
Post #487934 Thu Feb 18 2016 6:19pm
