![]() | Home > General > Replacement Key |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
Have a read through this topic over on the Disco forum
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Hi
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 ![]() ![]() |
Surely you do have a pattern as you have the spare key which also had a blade in it - or have I missed something. -
& the KVM module is only when the fob is lost which it isn't in this case, so that's also irrelevant. |
If you read the thread for the Disco forum you will see that a chap had a blade key cut from a photo he supplied......
The OP did mention the cost of a full key fob from a dealer, which is why I mentioned having to replace the KVM as well, so it is relevant if he were to do that. As far as the blade is concerned have to admit completely forgot about the one in the spare key. Cheers Col |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
Can order just the blade from LR which comes pre cut LR027978 £42.00inc vat
Cryptic23 Member Since: 08 Feb 2016 Location: manchester Posts: 8 ![]() |
Great forum.
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
I'm in Manchester and can do you a blade as I have them in stock for £20 cut to match yours 16 model year yulong white autobiography
