![]() | Home > General (L494) > Coolant Level Low |
richamartin Member Since: 16 Dec 2012 Location: Cotswolds Posts: 251 ![]() ![]() |
I had the same on mine, when it went off I drove it to LR dealer and they topped it up FOC.
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
Got a leak apparently. Was 5cm below the minimum but warning first time today! |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
My friend bought a brand new Evoque a few months back. 2 days later it left all its coolant on their drive and was taken away by LR assist!
Rose its head again this morning. Said it needs to go to dealer urgently |
Davemeldrum Member Since: 31 Dec 2016 Location: Dundee Posts: 1 ![]() ![]() ![]() |
Hello,
Hodog16 Member Since: 10 May 2015 Location: North Carolina Posts: 64 ![]() ![]() |
Old thread but just had this alarm come up today. It went away after a few seconds and as I had a short errand to run decided to see how the car did. No problems and temperature remained okay. Starting up on way home did not get alarm.
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Have you checked the level of coolant in the header tank? |
I did try to check and it's hard for me to see. It looks like the tank is L shaped or so. There's pink fluid on the left but the markers are at the bottom on the right and it looks like there is fluid there but it's hard to see. At any rate going to take it to the dealer on a Wednesday. 2016 SCV8 Dynamic - Firenze Red/Pimento |
Went to dealer today. They said the level was slightly low but did a pressurized test and there were no leaks. Topped off the fluid.
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 ![]() ![]() |
Same here, had it intermittently over the last couple of weeks. Couldn't face going to the dealer and getting booked in for what was likely to take a lot less time to fixed than waiting to be seen. Called Land Rover assist, who sent someone out. Exactly that, coolant was on the borderline so was only triggering. Topped up and did pressure test. All was OK. Range Rover Sport SVR - Santorini Black
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Water does expand a small amount with temperature, so this might cause it to rise and fall the critical amount to operate the level transducer. Probably better to top up over the line to avoid this happening. |
