Home > Technical > Engine Flush - Is it worth it?
rickshaw
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Have just booked my RRS in for its 3 Year Annual Service. They have recommended an 'Engine Flush' for an additional £25. Does anyone have any views or knowledge on whether it is of any benefit & worth the extra payment?
Post #487497 Mon Feb 15 2016 12:54pm
garrycol
Australia
Only if the coolant does not pass its specific gravity test - (it only needs changing every 10 years). 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #487499 Mon Feb 15 2016 1:12pm
I really do hope they are not going to do a Engine Flush with Coolant, the cooling system perhaps. Laughing
Post #487502 Mon Feb 15 2016 1:51pm
garrycol
Australia
I took the OP to be a coolant system flush.
If it is an oil system flush then if the engine has had its oil change at the correct intervals and the correct modern fully synthetic oil has been used then in my opinion it also is not needed. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #487505 Mon Feb 15 2016 1:59pm
Paddi
Re: Engine Flush - Is it worth it?
Engine flushes are just a money making scam for garages to rip off naive customers.
You will not find a qualified mechanical engineer who thinks they are a good idea. The flush products are just a strong detergent - some will remain in the engine after use - detracting from the lubricating properties of the fresh oil. The products are claimed to mobilise and remove oil sludge. If you are that worried about oil sludge then do two oil changes in fairly rapid succession but in a well maintained engine there should only be minimal sludge formation anyway and this will be removed along with the old oil at a scheduled service. 2008 MY Java Black TDV8 HSE
Post #487506 Mon Feb 15 2016 2:03pm
rickshaw
Yes - just to clarify they are recommending an OIL system flush. Thanks for comments so far - pretty much as expected but wanted to be sure Thumbs Up
Post #487532 Mon Feb 15 2016 5:17pm
I'm used to petrol cars, where you change the oil and it's either golden yellow or clear afterwards.
I changed oil on the RRS diesel and the oil's as black as the oil that came out lol ! Is this normal or do I need a flush?
Post #487557 Mon Feb 15 2016 8:48pm
garrycol
Australia
Its a diesel - they are dirty sooty things - all normal - in normal use just change the oil at the right time with the right spec. Change more often if used in arduous conditions (towing, constant city bumper to bumper traffic).
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #487583 Tue Feb 16 2016 12:34am
Stuart
[quote="Paddi"]
^^ This.
If you really want it, buy a bottle of stuff for under a tenner to pour in your oil, run it for half a day before you put it in the garage.
As others have said, it is normal for oil in diesel engines to go black quickly, and cars that have had oil changes at reasonable intervals wont really need anything extra. Its just an easy few quid for the garage: Bung some stuff in to idle for a while that costs them under a tenner (often free off reps). And charge you £25. Its an easy drink for them to flush an extra 25 sovs out of the dazed and confused who think there is some dark art going on during servicing. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #487584 Tue Feb 16 2016 1:37am
4X4BYFAR
In a diesel the lovely golden oil you pour in will be black within the first 100miles of use. It's not a problem.
Post #487807 Wed Feb 17 2016 6:34pm
4X4BYFAR
Waste of time and money, an in some older vehicles an engine flush can actually create problems.
Post #487808 Wed Feb 17 2016 6:36pm
That's assuming they ask the customer first. I've seen it on the work sheet after picking the car up from the dealership. Only ever been at main dealers though. Never seen it mentioned at an indie. 2012 SDV6 - it's missing a couple of cylinders
Post #487835 Wed Feb 17 2016 10:48pm
