Home > General > Suspension Stuck high
I have a problem with the suspension stuck higher that I request it.
It thinks it has come a ground but it hasn't.
Seams to be the rear at fault.
Is there a common fault which causes this exact issue?
Oh and I get a suspension over heat message on the dash sometimes.
Thanks
Post #487309 Fri Feb 12 2016 8:42pm
Bodsy
Site Sponsor
Ride height sensor (look at the 4x4 screen, it may indicate which one it thinks is stuck)
Wiring
Ride height needs calibrating if no sensor fault
Compressor overheating is because a) it's probably tired b) having to keep go into off road height is overworking it, so it gets too hot Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #487330 Sat Feb 13 2016 8:28am
Lost for Words
Blocked dryer also fits. Thumbs Up Visiting from DISCO3.CO.UK
Post #487340 Sat Feb 13 2016 9:55am
Thanks Guys
Yes the system has been complaining about the rear right.
Is the dryer part of the pump assembly or the valve block which I understand is in the front wheel arch ?
Post #487345 Sat Feb 13 2016 10:25am
Lost for Words
With the pump, but sounds like you've identified the issue anyway. Thumbs Up Visiting from DISCO3.CO.UK
Post #487346 Sat Feb 13 2016 10:30am
So you think its a sensor issue ?
Does anything mechanical go wrong with the "suspension airbags things" causing it to get stuck high?
Post #487349 Sat Feb 13 2016 10:50am
Lost for Words
If you've been having trouble with that corner, then yes, probably a sensor/calibration issue. Airbag leaks can sometimes occur as they age, but otherwise they don't seem to give trouble. Thumbs Up Visiting from DISCO3.CO.UK
Post #487351 Sat Feb 13 2016 11:14am
