Home > Technical > Adaptive Headlights not dancing
Page 2 of 3 <123>
Chris day
Mine don't dance and are pointing to low on the road. I'm shore they used be hire but now I'm thinking it might be same as you guys have going on. I have know Idea how to adjust hight so if someone one can tell me it would be very helpful please!
Post #448310 Tue Jan 13 2015 11:40am
pelle wrote:
Thank you for a fast answer.
I anderstand it is the same on LHD RRS.
Can you help me with the part-number for the ECU?
Best regards and all.
Pelle
YWC500440 according to the image earlier in the thread. 2012 SDV6 - it's missing a couple of cylinders
Post #448383 Tue Jan 13 2015 9:50pm
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
On top of the headlight as you look at it from the front end are two Hex Bolts. The outside bolt adjusts the 'left to right' and the inside adjusts 'up and down'
You will need a 6mm Alan Key which is at least 15cm long to reach the Hex bolt (cream/white in colour). Obviously park in front of a wall or garage to see beam when adjusting
Post #448416 Wed Jan 14 2015 11:00am
pelle
Sweden
Pelle
I think that is the AFS Power module, and there are two, one on each headlamp.
AFS control module, behind the CJB, is the part and number I am asking about.
pelle
Post #448418 Wed Jan 14 2015 11:13am
Chris day
Thanks for that Micalee. I wil have a look at the weekend. Heres to seeing in the dark again!
Post #448430 Wed Jan 14 2015 12:38pm
tone 123
England 2005 Range Rover Sport Supercharged Java Black
have the same problem lights don't dance or move on turning corners. changed afs module on headlight still nothing fuse ok. I have 55 plate S/C thanks again for help and info.
Post #459750 Sun Apr 19 2015 1:09pm
pelle
Sweden
Has someone with this problem fixed it until now? except robmeister1969.
I have not Sad
Post #487046 Tue Feb 09 2016 10:19pm
tone 123
hi pelle still not fixed mine. did have a go as you can see in my last post. and pulled the lights apart when I done the led thing everything ok. but to be honest my dads rrs has got afs and its not that good really. but I would say its what robmeister1969 has done cheers.
Post #487106 Wed Feb 10 2016 8:06pm
pelle
Sweden
I found the part number for the AFS ECU.
YWC500 322, YWC500 323, more.. YWC500 750.
I will try to change my now.
Post #490215 Mon Mar 07 2016 2:00am
pelle
Sweden
I changed my AFS ECU and my lights are dancing now. Thumbs Up
Post #490699 Sat Mar 12 2016 10:59am
tone 123
hi pelle was it difficult to do. whats the price for the ecu cheers.
Post #490712 Sat Mar 12 2016 3:46pm
pelle
Sweden
robmeister1969 has described the process in an other thread in this forum.
And yes, it is not easy but it is possible.
I found an ECU at a breaker?/ a place selling used part from damaged cars, in Sweden.
It was YWC500 323 from a 2006 RRS, mine old was YWC500322 a 2005 RRS.
After some bargin I payed about 100 GBpound/1200SEK including shipping.
Good Luck!
Post #490724 Sat Mar 12 2016 6:20pm
Dek Cross
Scotland 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi am having a similar problem RR sport 3.6 07 plate
Lights both dance yet once settled one is lighter and aiming higher than the other
Help
Post #502038 Tue Aug 02 2016 8:47pm
nich666
France 2008 Range Rover Sport 4.4 V8 HSE Stornoway Grey
Hi all, I have a 2008 RR Sport with hazed over headlights Grrr. Does anyone know if these Hex bolts mentioned above adjust for a LHD? (I live in France). Looking at replacements I can't find out if British RHD ones are changeable to LHD. Mine are the normal bulbs AFS 'Dancing' lights. I know that later lights had a small lever to change over for LHD but cannot find anywhere if mine do.
Another related issue is I am wondering if I found secondhand non AFS and fitted them would it upset the car as much as me.
In that year RR fitted three different headlight systems, it's barmy.
Post #528780 Thu Jun 22 2017 6:38pm
CraigJ
Scotland 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Hi Guys,
Only joined today,
I'm having the very same light problem.
My lights dance but periodically the drivers side settles
low.
Does anybody have any new ideas and did you Dek Cross sort
your light problem out and if so how?
Post #600960 Sun Jun 28 2020 6:20pm
Page 2 of 3 <123>
