![]() | Home > Technical > Key fob 2010 rrs |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Yes you can but will need to be programmed to your car. I have 2 off the newer ( thinner ) 2012 fobs working on my 2011. They are a lot thinner and fit in my pocket better. |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 ![]() ![]() |
Thanks for your reply I don't suppose u know what MHz key u have or the part number , as I am told there are 2 . |
Jason1wood Member Since: 27 Jan 2016 Location: Newcastle upon Tyne Posts: 13 ![]() ![]() ![]() |
My RRS only came with one key so would be interested in sourcing a new key and getting it coded |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 ![]() ![]() ![]() |
There are two frequencies the uk uses 434mhz although some people refer to it as 433mhz and overseas uses 315mhz. If you are buying one make sure it's 434 and don't buy a second hand one as it can't be coded. If your near Manchester I can code them in for you 16 model year yulong white autobiography
Thanks for your will sort one now I know the MHz cheers |
Second hand facelift keys can be reprogrammed, it's just the pre-facelift ones that can't. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
