![]() | Home > Technical > Steering wheel wobble under braking |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Have to be honest Never heard of Steering Wheel weight's or balancing.
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 ![]() ![]() ![]() |
Well beyond my pay grade, but I'd still put my money on warped discs. Worth checking the rear ones? |
TTF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 75 ![]() ![]() |
Nor had I, but apparently that is what it says on a LR bulletin according to Autologic! |
Rear ones shouldn't cause the wobble through the steering wheel, should feel it through the seat? What is worrying is that there is a specific LR bulletin about this specific issue, but no conclusive solution! Sounds like a Land Rover! |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
Warped discs would mostly be felt as pulsing through the brake pedal ...wobble could be worn lca bushings - tie rods - etc. I'd take it to a different indie - or suspension shop familiar with lr and get their opinion. |
The car is going into a different garage tomorrow; anyone had any similar experiences or known remedies before I drop it off?! Thanks. |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
TTF,
I think that is one of the plans but I cannot see how the alignment will affect a wobble only under braking and only through the steering wheel and not the brake pedal?! |
