![]() | Home > For Sale & Wanted > SOLD] Heated Steering Wheel |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
Heated Steering Wheel removed from late 2012 Autobiography, only removed because I changed Wheel for Sports Grip one.
andywatson Member Since: 03 Jan 2016 Location: Colchester Posts: 69 ![]() ![]() ![]() |
Hi Col,
Hi Andy,
Great thanks Col Mrs W will be pleased |
Hi Mark,
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Hi mate if it's not fitted from factory ie SE model it will need a clock Spring. Mine never had it.
Good price for the wheel Col. Bargain really. |
Thanks Mark,
Try and get a used one. Yes it's very simple to replace once air bag and steering wheel removed you will see the clock Spring it basically just pulls off once disconnected. Just remember to disconnect the battery and you'll need the air bag hook tool to remove the airbag.
This is the one you need LR018556 you can see the extra 2pin socket at the top if you compare with bottom picture. ![]() ![]() Wrong One YRC500070/80 Cheers Col |
Thanks guys,
SOLD
Chuffed to bits, Thanks Col and very well packed thank you |
