![]() | Home > General (L494) > Rear wiper blade |
Jarvis Member Since: 18 Feb 2010 Location: USA Posts: 16 ![]() |
http://www.rangerovers.net/forum/43-range-...wiper.html
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
Stopping the blade in the correct position, by opening the tail gate when the wiper is in the 6 o'clock position is not the issue. I just can not figure out how to make the space required to remove the blade, as the arm will only lift a couple of mm due to the roof spoiler.....
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 ![]() ![]() |
To get the rear wiper to stay in the middle of the window without haveng to open the boot at the exact time this works on my MY15.5
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
I tried the "open the tailgate" method - it worked. Precise method:
OK, so I revisited this today.
jonathanwarren Member Since: 09 Mar 2014 Location: Barnet Posts: 4 ![]() ![]() ![]() |
Does anybody know what wiper blade is required for the rear of a RRSport 2014 . There are none listed in all the after market suppliers that I can find.
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 ![]() ![]() |
The Original from LR is only 400mm long, a simple Standard Blade.
Thank you |
tover Member Since: 15 Apr 2016 Location: antwerpen Posts: 3 ![]() ![]() |
Hey Jonathan,
