Home > Technical > RRS TDI V8 G/box problem
Hoppa1950
United Kingdom 2013 Range Rover Sport SDV6 HST Firenze Red
I have had the sump and filter change on my 2007 V8 along with the correct make and quantity of oil but the problem still exists.
When pulling away with a cold engine and putting my foot down hard on the accelerator the engine seems to misfire and a transmission fault comes up and restricts the car operation.
When I pull over and recycle the ignition the engines starts no problem and from then if I drive slow there are no more problems and as soon as the engine warms up a little say 5mins I have no more problems.
If I put the box into command and change manually there doesn't seem to be a problem driving hard as long as I change up before the revs get too high.&
If I drive from cold slowly then there are no gear change problems apart from some times the gears are a little slow to change at certain refs and when taking my foot off there is a slight shunt when the box changes down.
Has anyone had this problem please.
Post #485560 Sat Jan 23 2016 6:37pm
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Hard acceleration on a cold engine..... getting that nice cold air charge out of the intercooler and throwing the map sensors into all sorts of wtf!
The car is telling you it likes to warm up gently so listen to it, otherwise you will soon be ordering some new turbos and a £4 k bill. 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #485564 Sat Jan 23 2016 7:52pm
Hoppa1950
Hello Mark
Thanks for the info and fully accept that but this had just started to happen and is not a thing I do often bug at times it us needed pulling out from where I live.
It has not done it in the last.
Thanks
Peter
Post #485566 Sat Jan 23 2016 8:03pm
Hoppa1950
Andrew
Andrew
Sorry for getting your name wrong
Peter
Post #485567 Sat Jan 23 2016 8:08pm
Disco_Mikey
Sounds very much like a blocked fuel filter
Have the fault codes read first, saves any guesswork Thumbs Up
Post #485570 Sat Jan 23 2016 8:15pm
Hoppa1950
Disco-Mikey
Thank you for that will get the faults checked and let you know
Regards
Peter
Post #485571 Sat Jan 23 2016 8:26pm
Hoppa1950
Disco_Mikey,
you were spot on the fuel filter was changed and the problem solved the car has now had the gearbox oill checked and took 1ltr and then the garage carried out a full system check and re-set.
Result the car is now driving great no stutters or shunting into gear while slowing down and changes up now without any hesitation.
Thank you for your help.
Peter
Post #485892 Wed Jan 27 2016 6:44pm
Disco_Mikey
Easy when you know Whistle
Great news it was a cheap fix Thumbs Up
Post #485897 Wed Jan 27 2016 7:04pm
Hoppa1950
yes mate and thanks a lot for your help true gent Thumbs Up
Post #485902 Wed Jan 27 2016 8:10pm
