Home > General (L494) > Satnav Software Update £352! |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 |
I dropped off my car at the dealer from where I purchased it on Wednesday for its first service. I asked them if they could update the satnav software as a few places I drive through occasionally have changed due to reconfigured roads.
Fri Jan 22 2016 3:46pm |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
£352 for a sat nav update! Was it one of the special platinum ones, with the diamonds on the side? |
Fri Jan 22 2016 4:49pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
£169 for the update http://landrover.navigation.com/product/Ca...erEMEA/GBP
Fri Jan 22 2016 5:54pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 |
Basically plug the Memory Stick into the USB port, use the touch Screen to input the Activation Code and leave it to update. Update takes about 3hrs. car needs to be left running as the ignition turns of to conserve battery if not started. Although if you turn ignition back on update continues to load from point it had reached when it turned off, but it get's a bit boring turning the ignition back on every few minutes so easier to leave running. Cheer Col |
Fri Jan 22 2016 10:57pm |
bluestone Member Since: 11 Aug 2015 Location: Manchester Posts: 155 |
Can the update disks not we downloaded from p2p sharing sites? MY16 (65) RRS, HSE, White, 21" 507s, Pan/Black Roof, 7 Seats, Ebony/Cirrus, Surround Cams, Fully Color Coded |
Sat Jan 23 2016 10:15am |
In the same way you can download copies of Spectre and Microsoft Office, yes. |
Sat Jan 23 2016 10:42am |
Just plugged my 2016 Memory Stick into Laptop and it shows 20gb of information, even in the instructions that come with stick it tells you the update can take up to 3hrs. and mine did for both 2015 and 2016 update. Cheers Col |
Sat Jan 23 2016 11:07am |
Not to sure about that, because when you buy the memory stick from Navteq or Here as they are now called, when you receive the stick you have to log into there site and register the stick and your vin. number, and a activation number is generated which you have to input via. the touch screen then follow on screen instructions. Not saying you can't download it from a site, but don't think it will be quite as simple as downloading a copy DVD, however I am not a Computer Wizz. |
Sat Jan 23 2016 11:18am |
Thanks for the information and help everybody.
Sat Jan 23 2016 2:10pm |
Lobster Member Since: 22 Feb 2009 Location: Adelaide, Australia Posts: 16 |
My new Aussie spec 2016 RRS is having vocal fits and stutters on a new freeway that has been open for 1 year.
Tue Jan 26 2016 4:33am |
This is for a MY13 L320 not sure if this how you access it on a MY16 L494.
Tue Jan 26 2016 9:31am |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
I've given up using the LR navigation. Instead, I use TomTom Go 6005 (I think it is) which has much better navigation, speed cameras, lifetime map updates, lifetime camera updates and lifetime live traffic. It is spot on on its predicted ETA's where the LR effort cannot make its mind up. Mark
Tue Jan 26 2016 9:41pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 |
I use CoPilot on my phone. Works well, updates for free, a small (£6 IIRC) annual fee for live traffic updates with live ETA updates and re-routing options accordingly. Cost about £25-30 to buy CoPilot initially.
Tue Jan 26 2016 10:16pm |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
I wonder will JLR ever sort out their nav? It really is so ancient.
Tue Jan 26 2016 10:48pm |
