Home > General (L494) > Frozen doors
eddkawasaki
Frozen doors
Found both my front doors frozen shut this morning, is there supposed to be ice in between the two seals?
only -3 and we couldn't get in the car. I hope we don't have a real winter!
I'm guessing this is why it leaves a nice splash of water on the seat when you open a door when its raining too.
Post #484903 Sat Jan 16 2016 12:57pm
Jaggs
Silicone spray on the rubber seals helps to prevent this Nanocom Evo
Post #484905 Sat Jan 16 2016 1:19pm
wilf
Yup - aerosol tin of Halfrauds silicon spray - spray onto a cloth then wipe around all the seals (and there are a lot of them on a Sport).
Don't spray direct from the can..............makes a mess. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #484916 Sat Jan 16 2016 4:10pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
I just use multi surface furniture polish. It gives the same result.
Jim
Post #484923 Sat Jan 16 2016 5:21pm
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
I had the same problem on a BMW convertible, where the frameless windows need to drop before the door can open. Following advice on a BMW forum I used gummi pflege. Absolute disaster! Muck everywhere and didn't solve the problem. I'll try silicone spray on the RRS. Might do it today as prevention, even if no problems yet.
Post #485010 Sun Jan 17 2016 4:05pm
eddkawasaki
Cheers for the tips I'll get some spray tomorrow. I think it was the very tops of the doors that were frozen not the actual rubber seals. theres a felt strip that probably should stop the water getting to the seals but its not doing its job so well
Post #485014 Sun Jan 17 2016 4:30pm
drdelrrs
Get some liquid silicone lubricant used by plumbers (Wickes or B&Q etc) . Rub a little on all exposed rubbers/trim seals with a cloth. Cheap and really effective and doesn't attack the trim.
Post #485033 Sun Jan 17 2016 7:34pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
or park it in the garage Whistle Very Happy
Post #485035 Sun Jan 17 2016 7:39pm
eddkawasaki
I would happily keep it in the garage but no one told my house builder that some people own cars longer than a fiesta. i managed to get it in once while i was offshore but its too close for comfort to be putting it in and out every day.
heres how close the back had to go to get the door shut......
there's about double that gap at the front
Post #485082 Mon Jan 18 2016 8:43am
362bkr
I know the problem ! I have a similar problem length wise so I have two fixed breeze blocks on the ground that my wheels hit before I hit the wall. Carefully does it Very Happy .
Post #485089 Mon Jan 18 2016 10:19am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Same here ... mine has to stay outside as my car park is accessed via a lift ...
The old RRS made it in at a squeeze ... but this new one just won't fit , theres about 5mm each side and you have to approach it at an angle....
Luckily we've had a mild winter so far but minus 15 nights are usually the norm ..... so thanks for the silicone tip 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #488343 Sun Feb 21 2016 7:36am
362bkr
I Would move house Whistle Very Happy
Post #488361 Sun Feb 21 2016 9:20am
