Home > Maintenance & Modifications > New DRL's fitted
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
New DRL's fitted
OK so the wife bought me some new DRL's for xmas to replace the horrid fading led drls that were previously there but i removed due to lights failing and mismatch in colour hue etc.
Now there's 100's out there to chose from in all kinds of price ranges but I went with what i thought were a reasonably priced set at just under £30, I was kind of limited due to the fact the size I required couldn't be no more than 130mm in length (or those of a certain age, 5 inches). These came in at 126mm.
The kit consisted of 2 sets of lights and brackets, 1 extension cable, a starter relay with very simple instructions. Even easier was that as i already had a drl relay loom fitted i only need join the live and earth from the already installed relay to the new kit.
These are the ones
http://www.hq-automotive.co.uk/lightning/5...-DRL-HQ-V9
[URL=]
[/URL]
As you can see nice bright white,
Only choice now is do i leave them as DRL's in which case they shut off when sidelights are activated (the halo smd rings) or should I alter so these to come on and stay on with the side lights?
[URL=]
[/URL]
Post #484583 Tue Jan 12 2016 9:49am
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
The ones in your link are 160 mm?
I was looking for some I could fit in the small grille areas of a AB bumper.
Post #484595 Tue Jan 12 2016 11:44am
Danv8
post ammended
Post #484598 Tue Jan 12 2016 2:03pm
Danv8
ok just double checked the advert and that says different size again. lol
http://www.ebay.co.uk/itm/311292159252?_tr...EBIDX%3AIT
These are definately the ones i bought and the fit in the little grills of the hst front bumper perfectly
Post #484599 Tue Jan 12 2016 2:09pm
