![]() | Home > In Car Electronics > OEM music player with bluetooth |
The head unit provides the interface between the CANBUS and the MOST loop, so if you remove it, you will have to loose the navigation, bluetooth, voice control etc. and, should you have had it enabled, the clock on the dash. I believe it has been relocated elsewhere in the car previously to retain the functions - a search on Disco3 should produce results. |
Put7kapu Member Since: 17 Dec 2015 Location: Lahti Posts: 16 ![]() ![]() ![]() |
Thats clear. Phone is already connected to hands free and Tom Tom navigator so im not sure is good option to stream from Phone anymore. Migth go with separate music player and maybe i use it as an navigator also. And maybe even something else also. |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
I am still considering buying this unit:
I bought cheap and simple 7 " Android table. You can have Navi ( google maps), spotify, youtube etc.
