![]() | Home > General > Rear and Front windscreen wipers reversed |
Pipes the wrong way round. |
Pc360 Member Since: 01 Dec 2014 Location: Warrington Posts: 3 ![]() ![]() ![]() |
Thanks for the quick reply, would it be the water pipe that have been reversed? The water is spraying on the correct screen it's the wiper action that's being reversed (sorry if I'm being a bit thick |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
There is no way they could connect the actual wiper stalk the wrong way as it is a multi-plug and will only fit one way. The other option is they have connected the washer pumps the wrong way round as you suggest, I don't know if this can be done or not as the plugs may be a different configuration. Saying that though nothing would surprise me with some of the dealer's so called technician's.
Pipes into the washer pump been fitted the wrong way? |
Yes, as Mikey says, the pipes have been put back on the wash bottle pump incorrectly. 2 minute job to sort. Happened to me when I had turbos replaced and they messed up replacing the body - several things not put back correctly. 2012 SDV6 - it's missing a couple of cylinders
Have I misunderstood this post or is the op saying the wipers work normally, however when he operates the rear screen washer it is the front wipers that work and visa versa, he doesn't actually say when operating the front washers it sprays on to the rear screen but refers to the wipers them self's when using the wash system. would that not be a electrical issue as opposed to reversed pipes. As I say I could be completely misunderstanding the post.
I think you're right, Col. I initially read it as, the wipers work normally when operated separately; the water sprays onto the wrong window but the wipers operate as expected, but it seems that's not it. So, the washers are correct; the wipers are correct alone, but are reversed with the washers? Visiting from DISCO3.CO.UK
