![]() | Home > Maintenance & Modifications > EGR blanking |
Yes, big ones at the top, though the upper blanks are optional - you can just blank at the bottom and leave the pipes there. That option is more discrete, but since discretion isn't specifically needed at present, I kind of prefer the full method (also gets the stubs out of the intake). |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
Great thanks a lot, Stubs... Is that the Butterfly part? Prise CAREFULLY the shaft, remove butterfly and replace shaft. |
The stubs are the end pieces of the pipes that stick into the butterfly housing (and when you take them out you'll see how covered in soot they are) - my logic is that removing them will give a slight improvement in airflow, but I don't for a moment think it makes more than a tiny, tiny , tiny difference (and if one wanted to get rid of them with the pipes in place, they could always be cut off anyway). |
Ahh, ha,ha I see, just looked at the diagram, the stubs really don't look healthy on the picture, with the butterfly is it just a case of easing shaft out, removing butterfly and replace shaft.. |
My advice, just fit the lower plates and leave the pipes in place, then everything will look standard, this maybe of importance at MOT time.
Yep. Some people occasionally report difficulties getting it out, but I haven't had an issue with the few I've done. I also suggest you take the opportunity to pop out the butterfly housing (just carefully maneuvre it out) and clean out all the soot with a bit of diesel. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Also think about a BAS remap and blank, now that does make a 2.7 fly. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
I've done errr quite a few |
Great help/advice, thanks all. |
Who says it's unnecessary? |
Ha, yes sorry my bad, always good to get more uummfff (unnecessary) was wrong choice of word, "extra stress"
Sounds like it could well be the TC, but not necessarily the whole box, but the bump could also just be play in the drivetrain or transfer box clutch calibration etc. What mileage? Was the oil OK, or smell burnt? Is it shifting well, and any faults on the box? The fact the gearbox has survived the flush and adaptive reset is one good sign. If it's the TC, I expect it'll make itself apparent sooner or later. |
Your trans id designed to take the V8, so a 2.7 is not an issue, I ran the Pete Bell (BAS) remap on my last Sport, made the car drive like it should have done.
124000, trans oil was dark but not burnt, shifts good, kick down works as should, not had any trans faults, lights, only other thing Iv noticed is when select reverse its not instant there is a split second delay to engage.
