Compuway
I received it a couple of weeks back and was completed at my service today at the dealers. From what I recall it is only an issue with RRS fitted with 19" wheels and only if you are on full left lock and the suspension is under full compression. The original LR 19's must have had clip on wheel balancing weights which must have been able to catch as the wheel turned under the above conditions. All they do is inspect the left hand front brake system for any signs of damage or premature wearing and replace the wheel balance weights with the stick on type.
If you have dynamic response and / or 20" wheels it is not an issue.
Cheers...Wayne 2006 RRS TDV6, Java/Alpaca, Dynamic Response Pack, Tow Pack, Head and Tail light protectors, 20" Stormers, Roof Rails, S/C Grill and Side Vents, Tasmods. AutoLogic mod.
1988 RR Highline, 3.5 EFI Arctic White, ARB Bullbar, Roof Rails, 15" Alloys, Front and Rear light Grilles, Side steps. (Still going strong)
