Home > Off Topic > Range Rover evoque won't start after airbag replacement
Newbie
Hi guys
Can anyone share any pearls of wisdom as to why my car won't start after having airbags changed? I've got an evoque 12 plate battery has been disconnected and Ecu reprogrammed
Post #482649 Thu Dec 17 2015 7:03am
Sorry i have no idea, so i can't help you.
Try posting it on here....
http://babyrr.com/forum/
Post #482651 Thu Dec 17 2015 7:29am
Newbie
Thank you
Post #482658 Thu Dec 17 2015 8:46am
As you have had airbags changed I guess you have had some sort of impact, just as a thought has the Inertia Fuel Shutoff Switch triggered as I imagine it has one off some sort, although you don't say whether the engine turns over or not, wouldn't know just a suggestion.
Post #482693 Thu Dec 17 2015 12:49pm
If a shunt, has the Megafuse blown? This isolates starter and alternator but allows power to rest of vehicle. 2012 SDV6 - it's missing a couple of cylinders
Post #482697 Thu Dec 17 2015 1:21pm
Newbie
It's been on a machine at a Range Rover specialist today who says the Ecu isn't talking to something I forget what and new software needs to be ordered from Range Rover garage said checked mega fuse as on battery it cranks but that's it
Post #482829 Fri Dec 18 2015 7:55pm
Tim in Scotland
I am the forum moderator of BabyRR.com and have owned two Evoques. I had a lot of problems on my first one with the Battery Management System that was causing the bettery to flatten very very quickly. It transpired that when the battery was disconnected to replace it the Land Rover Assist guy was not resetting the BMS after the reconnection of the battery. This is a stab in the dark as the problem was supposed to have been fixed with a TSB that was applied when cars went in for servicng. Once mine had had a new style of battery (an Absorded Glass mat battery) and a BMS software upgrade I never had another flat battery but it took 3 months of flat batteries to find the problem!
I have posted a link to this post over on BabyRR.com here http://babyrr.com/forum/Thread-Can-anyone-help-this-guy-please
and hopefully one of our tech savvy members on BabyRR will be able to help you out 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #482831 Fri Dec 18 2015 8:20pm
Newbie
Thank you will mention it to garage tomorrow cheers
Post #482834 Fri Dec 18 2015 8:58pm
