Home > Maintenance & Modifications > Recommended Land Rover Dealers/Independents in London? |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
If you can get out there, rovertune in reading have always been good with me and have a good reputation.... 2010 TDV8 |
Fri Dec 04 2015 7:11am |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
LR will just charge you ���������� and rip you off. That's labour charges alone
Fri Dec 04 2015 7:19am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
That would be your first mistake. LR garages are overpriced and most are, at best, poor in the quality of work and customer service. Find a decent indie/specialist and you will not only save money but you'll be getting better quality work done too. The LR logo in the service book should ring alarm bells for a potential purchaser! OEM parts are the way to go - the same quality as the original part but without the �100 that Land Rover charge for the box... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Dec 04 2015 8:39am |
Jit Member Since: 03 Dec 2015 Location: London Posts: 43 |
Spoke to Dan at Rovertune and its booked in for next week for brakes and minor service. I'm already put off LR dealerships from reading threads on here |
Fri Dec 04 2015 11:03am |
steve99 Member Since: 12 Sep 2015 Location: London Posts: 30 |
How much did Rovertune quote you for the minor service? |
Fri Dec 04 2015 11:25am |
�316 for the minor service. |
Fri Dec 04 2015 11:41am |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 |
I have had excellent customer service and prices at Guy Salmon Thames Ditton. Speak to Chris (owns a Evo) |
Fri Dec 04 2015 12:44pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Rob at Rovertune....top bloke Visitor from fullfatrr.com
Fri Dec 04 2015 5:05pm |
Is there anything else I should consider having done in terms of preventative maintenance whilst I am having the car worked on? It is exactly 5 years old and has 28K miles on the clock? I read somewhere about having the gearbox oil changed? |
Mon Dec 07 2015 12:06pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
At that mileage, I would do a basic drain and refill of the transmission and then continue to do the same approx every 25k. Leave it longer and a flush would be the best bet, so acting now would simplify things.
Mon Dec 07 2015 12:20pm |
Perfect, Ill get that done whilst I am there. A friend of mine thinks I should try and get a LR warranty on it and book it in with LR for a pre-warranty inspection. Is that an idea worth exploring? |
Mon Dec 07 2015 12:33pm |
Always worth exploring, but note that any issues found on the vehicle at present will have to be rectified, and so once you've paid for the inspection too, the value for money starts to drop quite a bit. There are 3 good options for a RRS owner:
Mon Dec 07 2015 12:47pm |
Ill look into warranty direct and see what that comes up with. |
Mon Dec 07 2015 1:07pm |
Just a small update on this. Took the car in to Rovertune. Can't really fault the work although the price was different to that I was quoted on the phone (ended up paying 487 which I am not sure is correct!). My other gripe was that I have been taking really good care of the interior since I bought the car (cream and black autobiography interior). It was literally spotless when I took it in and when I collected it there were a few grease marks on the door cards, the dash and the rear interior. |
Mon Dec 14 2015 12:17pm |
