![]() | Home > In Car Electronics > Sat nav takes 10 minutes to work on a morning |
11v at ideal is way too low. Sounds like early warning signs of alternator on its way out to just an old battery. Bodsys Brake Bible
RRS 1977 Member Since: 19 Apr 2015 Location: County durham Posts: 6 ![]() ![]() |
How do I check my alternator? Also will this affect my sat nav been slow to work on adaily start up! Also would you recommend a battery change the one I've got on is a yr old varta! Could it be a faulty cell thanks |
How do I check my alternator? Also will this affect my sat nav been slow to work on adaily start up! Also would you recommend a battery change the one I've got on is a yr old varta! Could it be a faulty cell thanks.also I forgot to mention last week my battery light on the dash would come on then dissappear after a few seconds not been on since! |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
If you fancy a run up to Northumberland I can check out the battery and charging system for you. I'm free all day on Wednesday this next week. |
