Home > Maintenance & Modifications > Replacement disc's & pads |
I would replace the brake pad wear sensors too. One on front, and one on the back. I would recommend inspecting the handbrake and cleaning it up, unless you suspect it needs replacing. |
Wed Nov 25 2015 11:36am |
Zack17 Member Since: 25 Nov 2015 Location: Shropshire Posts: 18 |
Thanks ,getting bit confused with disc diameters & relationship to wheel sizes ,I have 20" wheels can you point me up right path ? |
Wed Nov 25 2015 7:39pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
There will be 2 sizes of discs fitted to your RRS, 317mm and 325mm, for non-Brembo brakes. Or 360mm and 350mm rear for those models with Brembo front brakes
Wed Nov 25 2015 9:19pm |
Cheers , now to buy & fit ! |
Wed Nov 25 2015 9:27pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Try Advanced Factors for your brake bits - forum sponsor Visitor from fullfatrr.com
Thu Nov 26 2015 3:54pm |
Hi DrRob , thanks for the tip ,just ordered & had great deal brembo front/rear kits plus 5% discount at checkout ! ACE
Thu Nov 26 2015 7:27pm |
