Home > For Sale & Wanted > [For Sale] Heated Steering wheel suitable for 05-09
gvw
With kind permission from Martin, I have a heated steering wheel for sale posted on sister site disco3.co.uk Bow down
Just in time for the cold weather to help keep your hands lovely and warm Very Happy
Following my wheel upgrade marathon I have a used heated RRS wheel for sale http://www.disco3.co.uk/forum/topic125594.html
It is in good condition but not perfect - there are a few marks / indentations although not punctured as far as I can tell - see photos.
I've only had it a short time and have given it a clean and feed so perhaps they may go, perhaps not?
The heated switch on the rhs switch pack is not working as detailed in another post, hence ideal if you are fitting onto a D3 or early RRS as you would need to fit the BBS conversion PCB's and discard the current PCB's fitted as detailed in the post by BBS SPY
http://www.disco3.co.uk/forum/topic44385.html
Also consider you need the clock spring with the connected for the heater power supply, in order to get the heated element working - I'm not sure if these come as standard or not on the RRS Question
I've tested the wheel on my car with another rhs switch and proved the wheel gets warm when enabled.
The lhs switch pack has the AAC buttons and both switch packs have the chrome tip finish.
£210 delivered uk mainland
Any questions just ask and I will try to answer Thumbs Up
Post #480842 Tue Nov 24 2015 9:49pm
gvw
Few more photos after a couple of goes with gliptone
Post #480843 Tue Nov 24 2015 9:53pm
gvw
Now sold subject to usual Thumbs Up
Post #481665 Fri Dec 04 2015 8:15pm
