Home > General (L494) > Loadspace Accessories
Mark_N
I've spent a few hours this weekend fitting a couple of LR accessories to my SVR, the rechargeable torch and the illuminated stainless loadspace threshold.
It used to be the case that accessories were priced excluding installation and the dealer would quote. They are now priced including dealer installation but it's always the case that the book installation times (18 minutes for the torch, 30 for the loadspace threshold) put them under pressure. Since the installation involves what you might call craft skills - the ability to cut a hole in the right place or mount something straight - time spent getting it right yields better quality.
I learned this first hand when seeing the dismal quality of dealer installed mud-flaps on an Evoque - twisted and gappy - so I've always installed these things myself because I can do - and do do - a better job. Fortunately, it's possible to obtain the accessories from a helpful sponsor of this forum discounted by the installation cost so where the dealer installed torch costs something like �220, it can be had for less than half that.
The torch is easy to install but does require the left loadspace wall to be removed without breaking the clips holding it in place and there is no substitute for plastic pry tools which can apply the gentle pressure where it's needed. Grabbing the thing and yanking it off will lead to trouble. Once off, you have to use a jig-saw to cut the aperture required. It is marked on the reverse side so you just drill holes in the corners and cut it out, then finish it off with the file. You also have to cut away some ribbing to allow the holder to be fitted properly. The torch connects to a socket which is part of the wiring loom, so you have to make a hole in the sound adsorbing layer behind the panel to pass the cable through to connect to the wiring loom. The cable could do with being a bit longer - 30cm or so - to make for easy connection. The LED torch is nicely engineered, anodised aluminium and bright enough. It's charged when the ignition is switched on so will always be available as and when you need it. Granted, a mag-lite is a fraction of the cost but I like the carrier to store it.
Here's a picture of the loadspace (yes I know the car is dirty) after the torch was installed. You can also see the standard loadspace threshold which is a pretty low-rent affair compared to the stainless version I had on my Evoque, this in a �100k+ car.
The loadspace threshold comes in two versions, illuminated and non-illuminated and I had hoped it would be a string of LEDs but no, just the electro-luminescent panels used for the door thresholds. Given the extra cost and installation effort, I think the non-illuminated version smartens the loadspace without the gimmicky illumination and would be my choice next time round.
Installation involves removing the old threshold, 6 plastic rivets and 4 trim clips which need easing with the pry tools, transfer a couple of parts over to the new one and replace. If you've gone for the non-illuminated version, you are finished. For the illuminated version, you then have to route the cable up the side and long the bottom of the rear window to the connection point which is the interior boot light.
That's not the work of a moment and requires two right sidewall trims to come out, the coverings for the C and D pillars to come off and the top trim between them. Lots of clips, plastic rivets, a few bolts and screws. Finally, it looks like this...
You can see the cable to be routed in the wheel well and the parts/tool box has the blue pry tools which were very handy.
The instructions are quite explicit about how the cable should be routed, I think to avoid the cable interfering with the 3rd row seat belts which of course the SVR doesn't have anyway. With the help of the supplied cable ties, all is neat and tidy and the trim goes back together much more quickly than it came apart. It's clear the design is for ease of manufacturing but even so, there's a particular knack to installing the D pillar covers.
Finally, when it's all back together, it looks like this. The lighting is completely invisible in daylight, so I'll see how it is tonight...
 Mark
SVR in Estoril Blue Thumbs Up
Post #480658 Sun Nov 22 2015 3:23pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
Looks Nice Thumbs Up
Post #480668 Sun Nov 22 2015 5:26pm
jasons
2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Its dark out- where's the picture!! Smile 2012 RRS HSE. Firenze Red.
Post #480676 Sun Nov 22 2015 5:58pm
Mark_N
Here!
As you can see, the illuminated bit is not worth the bother. It's not going to cause any sort of navigational hazard to passing aircraft...
 Mark
Post #480678 Sun Nov 22 2015 6:07pm
jasons
I was expecting lasers shining out of the back!
Rolling with laughter 2012 RRS HSE. Firenze Red.
Post #480680 Sun Nov 22 2015 6:13pm
Mark_N
Hah hah, I think this might have been the first effort for the Spectre car and deemed a bit tame...
I see it cost me �265 + VAT LOL, �318 including.
The list prices on the LR configurator including VAT and installation are �365 for the non-illuminated version and �482 for this version. They must crack open a bottle every time someone orders one!
At least I saved �167 by installing it myself. Mark
Post #480681 Sun Nov 22 2015 6:16pm
Buckster
Looks very nice Mark Thumbs Up JLR certainly get a nice profit out of their accessories Big Cry 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #480691 Sun Nov 22 2015 7:30pm
Mark_N
Thank you, the message for me is clear. The stainless inserts are worth having, the lighting is not. Mark
Post #480695 Sun Nov 22 2015 8:05pm
JSR2014
England 2013 Range Rover Sport Supercharged Santorini Black
Yeah I went the cheap scape option and bought the unserts from Amazon USA for �40ish, 3M tape and they are fitted lol.
If anyone wants pics then let me know, I'm jealous of the torch but can't justify a �100 to swmbo lol. 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
Post #480705 Sun Nov 22 2015 9:42pm
udash
came across this on ebay, looks like it just goes over the existing one, so may not be as neat as the LR one but
http://www.ebay.co.uk/itm/221894837448?_tr...EBIDX%3AIT
Post #480774 Mon Nov 23 2015 9:06pm
Mark_N wrote:
Here!
Looks pretty Cool
Are you able to 'upgrade' the LED's to something brighter? ON THE WAY: BMW F21 M140i
Post #480780 Mon Nov 23 2015 9:37pm
Mark_N
That certainly looks a more cost effective option and much easier to install.
I did smile that the LR pictograms instructions want you to bin the original part, throwing good money after bad. Mark
Post #480849 Wed Nov 25 2015 6:06am
Mark_N
Beancounter_74 wrote:
Mark_N wrote:
Here!
Looks pretty Cool
Yes, you could replace the two electro-luminescent panels which run along each side with a circuit board populated with diffused white LED's with suitably modified power arrangements - the existing panels run off a high voltage, low current power supply I think - but I am not sure it would be worth the effort.
Still, when the panels go (even) dimmer or the tiny power supply brick you can see in the second photograph gives up, I might spend a rainy day of my retirement doing just that! Beats joining the local bridge club... Mark
Post #480850 Wed Nov 25 2015 6:13am
