Home > Technical > Heated steering wheel switch pack
Buckster
Does anyone know if the right hand steering wheel heated switch packs are the same for 2012 and 2013 cars?
Anyone have any part numbers and also does this need to be enabled in CCF? I am led to believe that the heated clock Spring is already present in a 2013 HSE Black Edition. Can anybody confirm who has done this?
I now have a heated steering wheel and am looking to retro fit this.
Many thanks Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #480491 Fri Nov 20 2015 11:44am
Bodsy
Site Sponsor
Pretty sure it is the same. I'm assuming it's the same model RRS and you're not trying to fit it to the new L494?
Usually needs to be enabled. Thumbs Up
Heated switch pack is about 80 istr Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #480494 Fri Nov 20 2015 12:20pm
Buckster
Thanks Bodsy, yes same model 2013 HSE Black Edition retro fit.
So I'm assuming the other part of the loom will already be on my clock spring, so I just need the switch pack then fit and enable?
Any idea what file this comes under of CCF? Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #480495 Fri Nov 20 2015 12:32pm
Bodsy
Site Sponsor
Depends on which tool you're using.
IID it's just called Heated steering wheel istr. Bodsys Brake Bible
See it HERE
Post #480498 Fri Nov 20 2015 12:50pm
Buckster
Yes IID, that's great thanks for your help Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #480501 Fri Nov 20 2015 1:08pm
