![]() | Home > General > Front drivers light - motor that lifts the lights up |
The motor isn't available separately as far as I can see. Have you checked all the connections etc.? Visiting from DISCO3.CO.UK
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Mine does this from time to time. A restart of the engine with the lights set to "on" usually makes it do its alignment "dance". Usually this works first time but sometimes it needs a second go. It's done this for the last 4+ years... 2012 SDV6 - it's missing a couple of cylinders
Mine has been doing this a fair bit the last couple of weeks so I've been done some reading.
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
My lights have never danced- MY 05. Should they? |
Only if you have the adaptive headlights fitted. Mine adaptive don't appear to dance very often but I think they do it when there is an ignition signal. This means that they can have done the dance before you turn on the lights themselves. 2012 SDV6 - it's missing a couple of cylinders
If I may wade into the "headlight dance" section...which is called the Initialisation Procedure
You can always disable them to fit non-adaptives. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Stephen J Member Since: 28 Oct 2013 Location: Amsterdam Posts: 16 ![]() ![]() ![]() |
I have encountered this problem recently. Previous posts are very helpful, but I was wondering what would cause these issues. Is it the servos in the light? If they move to a certain degree to prevent blinding, they are still moving, right? Any way to adjust these things? And if you replace the lights with non adjustable ones, what do you need to do to make sure it does not throw fault codes and all? Any information would be great, as long as I do not have to dish out a lot of money, I'm game. |
That would be a CCF edit, presumably. Hadn't thought of that to be honest. I haven't played with CCF using my IID for fear of doing something daft! ![]() 2008 TDV8 - it was a labour of love and is much missed |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Got a Brand New pair of Hella AFS Headlights in garage if anyone needs them. Intend to put them in for sale section when I get around to taking pictures.
Yep, a few things changed and then you can remove it all. ![]()
Safe as the IID is, it's never an unwise decision. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 ![]() ![]() ![]() |
Hi Guys mine has done the same thing twice now and it was the drivers side both time all i had to do was disconect and then plug back in turn the lights on and start the car and they did the reset also i did have a spare light that i took to bits but car,t see anyway or thing you can change and their is a guy up i manchester who sells second hand ones from conversion jobs in his body shop that he sells on ebay for 150 each thats the afs ones normal lights i think he was doing for 100. |
