Home > Technical > Heated Windows And Mirrors
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Hi All,
Had a search and can not find a diffinative answer, owners manual is not clear either.
On a 2012 AB, does the front and rear screen turn off automaticly? Do the heated mirrors turn on below a tempreture and with windows on only or automaticly?
Put my front and rear on this morning, drove to work, about 20 mins drive and they where both still on?
Post #480096 Tue Nov 17 2015 7:49am
The front and rear heated windows can be programmed to come on automatically if the outside temp is below 2 deg c. The rear heated window switch also controls the heated mirrors which is on a timer. Usually about 10 minutes. I found that my heated mirrors were crap compared to other vehicles i drive with them. To the point i ask my dealer to check to see if they actually worked. Whistle The front screen is on a separate switch, and is also on a timer. So i would have thought 10-15 minutes tops, before they should switch off. Then again, we are talking about a L/R product that has more electrical gremlins than the rest of the entire motor industry put together. Whistle
Post #480105 Tue Nov 17 2015 9:25am
the_big_1
lol might be a trip to dealers and there was no heat on the mirrors at all this morning and both front and rear where on for at least 20 mins and never switched off.
Post #480129 Tue Nov 17 2015 12:41pm
the_big_1
Hi guys,
The heaters are not as straight forward as we all think.
Here is a VERY detailed description and yes, mine are working correctly!
And who knew, heated mirrors are on more with your wipers!
Rear Window Heater
The ATC module controls operation of the rear window heater using medium speed CAN messages to operate the rear window heater relay in the central junction box (CJB). The control module in the CJB interprets the CAN messages and switches the ground connection of the relay coil to operate the rear window heater. While the rear window heater relay is energized, a battery power feed is connected to the rear window heater elements. Rear window heater operation is only enabled when the engine is running.
The ATC module operates the rear window heater in heating cycles of varying power and time. The heating cycle used depends on the ambient air temperature and whether it is the initial or subsequent operation during the current Power mode cycle.
When the rear window heater switch is pressed, the ATC module illuminates an LED in the switch and initiates the appropriate heating cycle. The LED remains illuminated until the rear window heater is selected off, the heating cycle is completed or the engine stops. If the engine stalls or turned off, rear window heating resumes if the engine is re-started within 20 seconds.
On the initial selection of rear window heating, the ATC module uses a short or long defrost phase at full power, followed by a low power phase. The defrost phase used depends on the ambient temperature. During the low power phase, the rear window heater relay is cycled off for 80 seconds and on for 40 seconds.
On subsequent operations, during the same Power mode cycle, the ATC module operates the rear window heater at full power for a fixed time period.
Rear Window Heating Phases
Phase Time, minutes
Short defrost (-5°C (23°F) and above)
    10
Long defrost (less than -5°C (23°F))
    15
Low power
    20
Subsequent operation
    10
Windshield Heater
The ATC module controls operation of the windshield heater using the windshield heater relay in the BJB. The ATC module switches the ground connection of the relay coil to operate the windshield heater. While the windshield heater relay is energized, a battery power feed is connected to each of the two windshield heater elements. Windshield heater operation is only enabled when the engine is running.
The ATC module operates the windshield heater in heating cycles of varying power and time. The heating cycle used depends on the ambient air temperature and whether it is the initial or subsequent operation during the current Power mode cycle.
When the windshield heater switch is pressed, the ATC module illuminates a LED in the switch and initiates the appropriate heating cycle. The LED remains illuminated until the windshield heater is selected off, the heating cycle is completed or the engine stops. If the engine stalls or turned off, windshield heating resumes if the engine is re-started within 20 seconds.
On the initial selection of the windshield heater, the ATC module uses a short or long defrost phase at full power, followed by a low power phase. The defrost phase used depends on the ambient temperature. During the low power phase, the windshield heater relay is cycled off for 80 seconds and on for 40 seconds.
On subsequent operations, during the same Power mode cycle, the ATC module operates the windshield heater at full power for a fixed time period.
Windshield Heating Phases
Phase Time, minutes
Short defrost (-5 °C (23 °F) and above)
    3
Long defrost (less than -5 °C (23 °F))
    5
Low power
    10
    3
Exterior Mirrors
Heating
The CJB receives the ambient air temperature value from the ECM (engine control module) on the high speed CAN bus. The CJB converts the ambient air temperature value to an on-time percentage and transmits it on the medium speed CAN bus to the two door modules, which then energize the exterior mirror heating elements accordingly. The on-time percentage is increased while the windshield wipers are on.
Exterior Mirror Heating Percentage On-times
On-times Ambient Air Temperature, °C
    Less 8 8 to 15 15 to 25 Over 25
    Wipers Off 50% 33% 0% 0%
    Wipers On 50% 33% 25% 0%
On vehicles with the parked heating function, exterior mirror heating may also operate when the parked heating function is active, depending on the ambient air temperature.
Post #480464 Fri Nov 20 2015 7:44am
Bill Portland
^^useful post^^
is it a given that heated mirrors are included on all RRSs?
I have to say, i've no evidence that i have them, seems to take an age to clear them of frost or dew, but maybe i should turn the wipers on more!
Post #517220 Thu Feb 09 2017 12:30pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Having moved from a 2007 to a 2012 I too thought my heated wing mirrors weren't working so mentioned it the dealer when it was in they came back with the response above. It would appear that the elements cycle on and off but seem mainly to be off! If i'm lucky they might clear after my 15 minute commute to work...such a shame the 2007 mirrors cleared so quickly..
Post #517246 Thu Feb 09 2017 3:02pm
Tim in Scotland
My L494 sits out on the drive all year round and I have never noticed the heated wing mirrors come on, during the icy spell we had in November I had my front windscreen replaced and now there is a sizable delay between it coming on and the rear one coming on, the rear can be almost defrosted before there are any signs of life from the front screen, I wonder if it is part of the Battery managament system to reduce cold weather load on the battery? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #517253 Thu Feb 09 2017 4:47pm
On the early RRS the mirrors were on too much if anything Laughing
One day they might get the right balance.
It sounds like your replacement windscreen isn't very good! or maybe not a genuine part. That is a real shame.
I'm fairly sure the battery management has a priority system. And priority No,1 would be the drivers side of the front windscreen.
Post #517256 Thu Feb 09 2017 5:40pm
RallyXS
You must need new ones. I had one side working and one not, and the dealer replaced one. You can actually see the moisture evaporating off them, so yours can't be working. 2012 RRS SDV6
2014 BMW 320d X-Drive Touring
1999 VW Polo stage rally car
Post #517275 Thu Feb 09 2017 9:14pm
Pufftmw
Parking on London streets, I fold my mirrors in and they don't seem to require defrosting in the morning because of this Very Happy
Post #517965 Thu Feb 16 2017 2:37pm
yeah it's a good plan on cold nights.
make it easier to shift most of the ice of the windscreen too.
Post #517982 Thu Feb 16 2017 5:55pm
