Home > Technical > My EPB - handbrake some times makes the squeel when applied.
lamb190
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Rimini Red
As above since owning my RRS Since June, the EPB has made the 'squeel' noise a dosen times since When applying it (not releasing it)
With searching, and being diverted to the disco forum i now know how to adjust and set up the shoes in the rear discs....
But before i do anything i wanted to know is my EPB likely to be ok as it is, or PRIOR to adjusting the shoes do i need to open up the EPB module and wind back the rod. ? As i suspect the squeeling is from the adjuster maxing out?
If this is the case... hows best to access the EPB. It looks very hard to get at, and no i dont have car ramps Big Cry
Spencer
Post #479847 Sat Nov 14 2015 9:50pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
If the EPB only squeal occasionally, You "only" have
to adjust it.
Put car on stands, remove rear tires, and adjust through
the little hole..
The same happened to my brothers car, after exchanging rear pads,
the EPB squealed, but after adjusting it works fine..
I guess that You have seen "Bodsys Brakebible"?
Otherwise: http://www.disco3.co.uk/gallery/thumbnails.php?album=4184 here is the link..
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #479866 Sun Nov 15 2015 12:57am
cannon-fodder
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
My EPB was making the odd squeal couple of months ago, turned out to be the inside of the rear discs, where the brake shoes are located, were badly rusted. A new set of rear discs stopped the occasional squeal I was getting Very Happy - may be worth checking.
Cannon-fodder
Post #479880 Sun Nov 15 2015 9:57am
lamb190
Cheers guys. Now with bodsys bible to hand ive adjusted the shoes as per his instruction. And both my rear brakes shoes must have been 10 clicks or so off where they are now.
Rear discs look fairly new so probibly needed re adjustment. Cool
Post #479888 Sun Nov 15 2015 10:27am
Bodsy
Site Sponsor
Great result. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #479907 Sun Nov 15 2015 1:32pm
