Home > Technical > Break and gear shift click when applying the break |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
I have this as well but mine is only in neutral. As you say press brake pedal up and down click click from the gear stick I'd like to know as well. Not causing no issues. |
Thu Nov 12 2015 12:56pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Shift interlock solenoid. I'd say it's normal to hear it - perhaps since the brake switch has been changed, it happens more readily so you're now noticing it?
Thu Nov 12 2015 12:58pm |
Lee69 Member Since: 15 Sep 2015 Location: Liverpool Posts: 24 |
thanks for getting back
Thu Nov 12 2015 1:06pm |
Since the power to the solenoid is provided by the Transmission Control Module (TCM), it seems unlikely that it would actually make it louder, but the ECUs are significantly affected by the brake switch - not least the TCM - so perhaps it could be down to the behaviour of the ECU. Visiting from DISCO3.CO.UK
Thu Nov 12 2015 1:35pm |
sorry for being thick but what does that mean in English haha
Thu Nov 12 2015 2:07pm |
It just means maybe the signal provided from the brake switch has been affecting the manner in which power is provided to the solenoid.
Thu Nov 12 2015 2:26pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
O/T: What is this app? Regards etc.,
Thu Nov 12 2015 2:33pm |
IID BT Visiting from DISCO3.CO.UK
Thu Nov 12 2015 2:36pm |
I think I will buy a new one an see how it goes.
Thu Nov 12 2015 5:24pm |
