Home > Faults & Fixes > Hollow sounding knock from rear
idrabble
Australia
I'm hoping all the experts on here can point me in the right direction.
I have a hollow sounding knock coming from the rear of my 2005 TDV6, and this happens when I go over small bumps in the road & speed humps etc.
I'm guessing it's either rear anti-roll bar bushes or control arms. Which is the most likely culprit?
Cheers in advance, Ian
P.S. don't think it's the rear tuning weights as I have given these a good swing about and cannot get a squeak out of them.
Post #478959 Fri Nov 06 2015 3:11am
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Knock on braking could be control arm , if it is when you are going straight down the road and small bumps- I would replace sway bar bushings and drop links - cheap to do and any shop that does suspension work should be able to this for you ...
Also double check it is not cargo cover rattling first or loose exhaust pipe ...
Post #479038 Fri Nov 06 2015 10:16pm
MattMatt
United Kingdom 2007 Range Rover Sport TDV6 HSE Zambezi Silver
Had exactly the same thing - changed the ARB bushes for good quality ones (polybush) and it all went away.
Post #479360 Tue Nov 10 2015 4:22pm
