Home > Maintenance & Modifications > 2012 MY Hockey Stick Replacement
jasons
2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Hi all,
Desperate to get rid of the wood trim and am just about to,push the button on a black set, however, I haven't been able to find any info on the forum, or online on how to do it.
Plenty on the previous model, but nothing on the facelift.
Has anyone done it or have a guide on how to do it?
Thanks,
J 2012 RRS HSE. Firenze Red.
Post #477305 Wed Oct 21 2015 4:49pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I put this info up before, all. I can say is get ready for a major strip down of the centre console just to fit these Big Cry
You have to literally remove the whole top console and strip down the cup holders and ashtray and remove the gear surround just to get at the screws. It is a pain in A Censorede also all the clips will break when removing the console you'll need to get replacements. "I know this"........ :whistle
Don't break nothing otherwise you'll be Big Cry
Post #477308 Wed Oct 21 2015 5:07pm
jasons
I thought I'd update....
I've tried twice now, both times I've given up. Big Cry
I've manage to raise the trim up, except the part around the gear selector- it just won't budge...
Giving up again for now. 2012 RRS HSE. Firenze Red.
Post #478787 Wed Nov 04 2015 1:14pm
ABSport
Just to give you a update Sad
As you have the rotary selector it is all attached to the main gearbox unit in the console. hence why trying to pull it wont budge Big Cry
If you had the gear lever pre-2012 you simply remove the gear lever ( this pulls straight off. ) and the gear selector stays put. Although the toughest part for me was pulling the console off and pinging all the clips off. Making sure you don't break nothing.
Land rover should of made the Hockey sticks a clip in flush part not a major strip down. As I said all the cup holder compartment and ash tray have to be removed just to get at the screws which fix the hockey sticks. This has to be removed and turned upside down to get at. All the wiring has to be uncliped which feeds the heater controls, rotary gear selector, and park brake, have to be unplugged as well. Again a pain in the back side.
I then had a few hrs of gearbox fault, park brake fault etc etc once all plugged back in. I did a full re-set on the car Mad which eventually cleared the faults.
You could try getting some gloss black wrap and a hair dryer sharp stanley knife and doing it that way. I know someone who has done this and they got scratch resistance wrap in a gloss black. Thumbs Up
Post #478960 Fri Nov 06 2015 5:10am
Gary7734
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi Jason,
If you have the 2011 model with facelift and rotary gear selector I have a full set of instruction, done mine last year and takes about 30 minuted once you get the hang.
Post #479053 Sat Nov 07 2015 9:21am
jasons
Yes I have, and if I can do it I'll have your babies!
Seriously, if you could let me have them I would be genuinely grateful- I don't like not being able todo something and it's been driving me mad this week trying to figure it out!
Cheers,
Post #479056 Sat Nov 07 2015 9:33am
Gary7734
I'll look at home tonight for the schematics, from what i remember though;
remove CD slot cover with small thin blade, just pops off, remove screws now visible, the whole centre console will now lift up, disconnect the electrics, 2 fittings that just separate, this is the rotary connector and height adjustment, ruen upside down on a flat surface, and unfortunately has to be totally stripped down from their to access hockey stick screws, straight forward and I managed and am totally non technical.
As said though , will try and find instructions tonight
Post #479058 Sat Nov 07 2015 9:41am
Gary7734
Jason,
found it at work, PM me your email and will forward the PDF
Post #479059 Sat Nov 07 2015 10:03am
jasons
PM inbound.
Cheers buddy.
Post #479069 Sat Nov 07 2015 11:53am
Sandeep nijjar
Austria 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hello every body..
Is some one active here to talk about issue..?
Any help regarding changing hockey sticks on center console on RRS 2012 facelift with rotary gear knob will be appreciated.. Very Happy
Thanks
Post #616625 Mon Aug 16 2021 2:43pm
Sandeep nijjar
Sample pic
Post #616626 Mon Aug 16 2021 2:56pm
Sandeep nijjar
Sample pic
Post #616627 Mon Aug 16 2021 2:57pm
