Home > General > Shaking Rangie |
smiler148 Member Since: 06 Sep 2015 Location: forfar Posts: 28 |
Sounds like a brake caliper may be sticking on sometimes.
Fri Nov 06 2015 6:59pm |
MOLDY99 Member Since: 20 Sep 2014 Location: Belper Posts: 4 |
Many thanks for taking the trouble to reply. It's a good thought but the car drives in a complete straight line with no wandering left or right at all even when the problem occurs. It's going for an mot soon and I have an extended warranty that covers pretty much everything so it might be a good start. Thanks |
Fri Nov 06 2015 7:11pm |
No problem.
Fri Nov 06 2015 7:21pm |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 |
do you have the cruise control on when this happens |
Sat Nov 07 2015 7:12am |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 535 |
+1 for the sticking calliper...had this happen before... The car will give you no indication of a brake binding I.e. Pulling to one side... Car will drive completely normally... What happens at normal speeds the brake disc and pad can dissipate the additional heat relatively easily but at motorway speeds the heat builds up so much that the disc starts swelling with the heat and hot spots on the disc cause it to start oscillating within the carrier hence the shaking steering. You pull over and it doesn't want to move. You leave it five minutes or so and you can drive on as if nothing had happened...( because the disc has cooled sufficiently and almost returned to shape) five minutes further up the motorway the problem will return...
Sat Nov 07 2015 7:55am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
The above is correct
Sat Nov 07 2015 7:58am |
