Home > Technical > Brakes stuck on! |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
EPB jammed the rear shoes. you will need to strip the rear drums to find out the problem, common on the sports and Discoverys. |
Wed Nov 04 2015 9:14am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
If you bought from dealer should be covered under warranty Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed Nov 04 2015 9:16am |
Panavia man Member Since: 27 Oct 2015 Location: North west Posts: 94 |
Ok thanks both for the replies. I got a warranty wise policy with it, lets hope its covered! |
Wed Nov 04 2015 10:07am |
Don't be fobbed off - it's dealers responsibility regardless of what warrantywise say
Wed Nov 04 2015 10:11am |
Just spoken to the dealer who suggested I try warranty wise first! |
Wed Nov 04 2015 10:28am |
They would as they are hoping not to spend anything Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed Nov 04 2015 11:35am |
I've pushed back - it's off to a LR specialist garage now. Sure they will diagnose it quickly. It does make a horrible noise when you try to release it the parking brake! |
Wed Nov 04 2015 12:37pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
They don't need to; it already has been... Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Wed Nov 04 2015 12:46pm |
Yes - sounds like it! I'm new to this game, I believe it's best to leave the handbrake off on these? Looks like the last owner hasn't been using it and it's locked now I have started using it. |
Wed Nov 04 2015 12:55pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
If you use it, the shoes wear, go out of adjusted, and squeak
Wed Nov 04 2015 1:00pm |
I only used mine on hills when parked - my DS comes on automatically when I stop engine which is a pain Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Wed Nov 04 2015 1:06pm |
As Mikey says, using it needs maintainence, not using it needs maintainence - you may as well take advantage of it (and you don't want to put strain on the parking pawl). Visiting from DISCO3.CO.UK
Wed Nov 04 2015 1:07pm |
Thanks for the replies. I'm a bit dissapointed as the car is a one owner with a full service history. Surely EPB should have been maintained regardless of use? |
Wed Nov 04 2015 1:10pm |
I wouldn't be too disappointed - it often doesn't get the attention it needs, and if you don't have a trustworthy mechanic, it can be hard to know if the EPB has been done properly unless you've done it yourself. It may well be time for a new set of shoes - mine were in a right state when I first went to change the brake discs. Visiting from DISCO3.CO.UK
Wed Nov 04 2015 1:21pm |
