Home > Maintenance & Modifications > coolant flush
Gilly1
coolant flush
hi, I recently had a service and on the need to do list was coolant overfilled and under strength, (I DIDNT DO THE OVERFILL) Mr. Green was hoping someone could tell me what coolant\antifreeze I should use and how to drain and refill the system (bleed) if need be, 2.7tdv6. Confused
Post #476398 Wed Oct 14 2015 6:29pm
Bodsy
Site Sponsor
You need OAT coolant, 50/50 mix
Undo one of the lower hoses to drain (you need to remove the underbody cover first)
Then refill 50/50
Bleeding needs to be done by following a revving process, pretty sure it's already listed on here. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #476415 Wed Oct 14 2015 9:00pm
Gilly1
Cool, thanks bodsy Thumbs Up
Post #476479 Thu Oct 15 2015 2:26pm
Gilly1
Is this suitable for my 2005 RR sport TDV6 or shall I just buy from Land Rover,
Going to drain system buy removing bottom rad pipe, let coolant drain, fill with straight water, run car with heater on full, let the water circulate, let system cool, drain again and then refill with 50/50. WILL THAT WORK OK....
Post #478286 Fri Oct 30 2015 1:51pm
Paddi
When I drained mine from the hoses the volume collected was a few litres short of the total capacity quoted in the manual. So on that basis I would advise you to just drain and refill. If you fill with straight water and drain there will be a lot of straight water left in the engine. Not good. 2008 MY Java Black TDV8 HSE
Post #478298 Fri Oct 30 2015 3:05pm
Gilly1
Thanks paddi, I'm just a bit concerned about mixing coolant as I'm not 100% what is in the system currently, all I no is what is in system currently is under strength.
Post #478344 Sat Oct 31 2015 6:21am
Paddi
Perhaps you could drain, refill with the Halfords OAT, drain again and then fill with more of the same? Means wasting a bit of coolant but its not that expensive is it? If using the concentrate, dilute with deionised water not tap water though. 2008 MY Java Black TDV8 HSE
Post #478347 Sat Oct 31 2015 9:35am
Lost for Words
If you flush with water, you should be able to calculate approximately how much excess water has been left in, by the volume you get out, and adjust the ratio of antifreeze accordingly. That'd be accurate enough, and if in doubt, use a little more coolant (keep that to a minimum though, for best efficieny). Thumbs Up Visiting from DISCO3.CO.UK
Post #478348 Sat Oct 31 2015 10:03am
Gilly1
That's what I was thinking, just go maybe 55 coolant and 45 water, Iv just been to stealers and purchased there Land Rover special label coolant, now Iv decided on coolant and purchased it Iv got another dilemma, I was under the impression Land Rover coolant was orange, looking through the clear strip on side of container it looks green. Rolling Eyes am I just being OVER CAREFUL and should just get on with it...
Post #478349 Sat Oct 31 2015 10:12am
Paddi
I thought that too but if you pour it out is is actually amber coloured! 2008 MY Java Black TDV8 HSE
Post #478383 Sat Oct 31 2015 10:23pm
