Home > My Range Rover Sport > 2008 fire damaged sport 2.7tdv6 hse project
Page 4 of 4 <1234
Disco_Mikey
That's the one Thumbs Up
Compare your chassis number to those listed in the bulletin posted above Thumbs Up
Post #478297 Fri Oct 30 2015 3:52pm
Charlie41
Hi Col and Mickey, this was my chassis number SALlSAA237A992126, Range Rover Sport HSE , first reg. 6/03/2007. Does this chassis number fall into the category? Thank you ever so much
Post #478318 Fri Oct 30 2015 9:06pm
Disco_Mikey
Re-reading those chassis ranges, there appear to be a few errors in them
Give me 20 mins
Post #478320 Fri Oct 30 2015 9:34pm
Charlie41
Ok thank you ever so much
Post #478321 Fri Oct 30 2015 9:43pm
Disco_Mikey
If that chassis number is definitely correct, then you have a 3.6 TDV8, which was not affected by this recall
It only affected the 2.7 TDV6
Post #478322 Fri Oct 30 2015 9:49pm
Charlie41
Ye Mickey, chassis number defo correct. My Range Rover went on fire at 6.00am in morning in carport. It had not be driven since 5.00pm previous day. It was not arson. Something seriously went wrong with it. Because it was so badly fire damaged, completely destroyed the phrenic guy in fires done a full written detailed report, but because so badly damaged could not pin point where the fire started in the jeep. Can u suggest anyone I could send report to eg: a specialist in Range Rover car fires? The report is very detailed, and loads of pics as well.
Post #478323 Fri Oct 30 2015 10:00pm
Disco_Mikey
I wonder if it was a faulty alternator Question
Post #478324 Fri Oct 30 2015 10:03pm
Charlie41
Why do you think alternator?
Post #478325 Fri Oct 30 2015 10:06pm
Disco_Mikey
When they fail, they can cause an alarming amount of smoke as they short circuit, and draw 400 amps out of the battery...
Post #478327 Fri Oct 30 2015 10:07pm
Charlie41
Is there anyway I can send you report and pics. It is very detailed. I have a little boy with special needs who lost a lot of specialist equipment and toys that were on the deck. My insurance will not cover these or the deck area as they say it was an add on. The carport that I had built especially for him is not covered either. He loves outside. The deck area also had a roof , whole area approx 30ft x20. The fire really effected him. I had bought Range Rover as I thought it was a safe wY of transporting him as he has being through so much.
Post #478330 Fri Oct 30 2015 10:13pm
Disco_Mikey
I'm no expert at forensics, but send it over to my email, and I'll take a look through it Thumbs Up
Mike@mmplandrover.co.uk
Post #478331 Fri Oct 30 2015 10:14pm
Charlie41
Hi Mickey, can't get doc to email as I think it's to big. I have taken pics of full reports, there are actuall 2, I see you have facebook page, can I send the pics and documents on there via private message?
Post #478333 Fri Oct 30 2015 10:31pm
Disco_Mikey
Post #478338 Fri Oct 30 2015 11:07pm
Page 4 of 4 <1234
