![]() | Home > General > Sport on 22" rims |
I have a 5.0L S/C running on 21" SVR Rims and it drivers perfect, if you have had a issue with two sets of wheels and tyres I would be inclined to think the issue is with the car. Have you had a 4 wheel alignment done? as that would be a good place to start and go from there, what tyre pressures are you running?.
Quarryman223 Member Since: 27 Apr 2014 Location: Somerset Posts: 9 ![]() ![]() |
Morning Col
SPX Member Since: 26 Dec 2012 Location: South Yorkshire Posts: 587 ![]() ![]() ![]() |
Have you tried swapping wheels between the Disco and the Sport? |
No I've not tried that mate, mite be worth a go! |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
its the car, something is not aligned properly, I had 22 on mine, rock steady all the way upto 3 figures.
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
I love my 22's and have no issues whatever speed i Drive. Don't understand what all the fuss is about people not liking the ride!??!!??!?! |
Not sure where in Somerset you are, but if you're within reach, I'd (very highly) recommend Steve Norman: http://www.tandsnorman.com/ (Just south of Shepton Mallet) He can check all your alignments etc. and I'm sure would get to the bottom of it. |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I'm no expert- but wasn't there an issue with the steering rack needing to be updated to manage 22's? Maybe your issue? I have 22's and find the ride fine. Have driven another sport on 19's which was undoubtedly smoother- but not massively in my opinion |
There was an issue between 2005 and 2007 running RRS1 on bigger than 19" rims without an updated steering rack or the Dynamic Handling Pack. After 2007 Land Rover decided that RRS owners might want to run bigger wheels so the uprated rack became standard across all models. 4.4 and S/C had it as standard from day one. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks for all the info guys!
Called Steve this morning and the truck is with him already!! after a test drive he agrees there's something wrong and its pointing towards the rear end set up! Thanks for recommending him "Lost for words" Will keep you all posted as to what they find......looking forward to shoving the results up the local Land Rover dealers Arse too!! Thanks again for all the replies. |
He's a top chap. |
Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78 ![]() ![]() ![]() |
Mine is a TDV8 registered 30/01/2007, on factory 20" wheels how can I tell if mine has the uprated rack or the older rack? just out of curiosity? Thanks |
crammy Member Since: 21 Aug 2014 Location: essex Posts: 167 ![]() ![]() ![]() |
i would of thought yours has it wilson if the wheels are factory 20's and they new about the problem with wheels larger than 19 but you never know i guess |
