Home > Technical > Speedometer Question
kaupozito
Estonia 2007 Range Rover Sport TDV6 HSE Java Black
Hei all!
I have a problem with my car speedometer, all the gages,lcd and backlight dies and gomes right back sometimes longer 5 minutes, makes it very often. Some days are quite okay dont do it, and then starts again.
Post #476492 Thu Oct 15 2015 5:57pm
stricko
2006 Range Rover Sport TDV6 HSE Zermatt Silver
I had the same problem with mine. It started off only hapenning now and then. After a while it got more frequent and in the end it needed a new instrument cluster.
Post #476534 Fri Oct 16 2015 4:51am
kaupozito
Thank you for answering!
Do you buy immediately new or you ask someone to repair it before?
Post #476546 Fri Oct 16 2015 7:55am
stricko
My local indie garage had a good look at it first.
They took it out and cleaned up any connections etc then put it back. It did seem to be a bit better after that for a while, but then got worse again.
I found a few places online who said they could refurbish the existing unit, but in the end I went with a new one for peace of mind
Post #476549 Fri Oct 16 2015 8:00am
kaupozito
Do you buy secondhand or new part? How much was it?
Post #476552 Fri Oct 16 2015 8:09am
stricko
It was new. I cant remember exactly but it was around £350 + installation. I think £500 in total (approx)
Post #476616 Fri Oct 16 2015 4:17pm
kaupozito
I'll let you know when I get fix.
Post #477304 Wed Oct 21 2015 4:49pm
Si5974
My speedo and rev counter needles were suffering intermittent lighting problems
Took it back to dealer, they had a look and then put a new instrument cluster in. There's a couple of other threads on here (I did a search when mine played up so was happy when the dealer diagnostics matched the experience on this forum)
It was a warranty fix so can't help with prices but it seems the fix is by replacement. Crying or Very sad 26 Jun 2015 - Just bought my dream car - 😀 2010 RRS HSE
Gone - A5 177 Black edition
Gone -A4 177 Black edition
Gone - Ducati 748 😂
Gone - Fireblade 😂
Post #477563 Fri Oct 23 2015 4:39pm
