Home > General (L494) > L494 dislikes? What drives you bonkers on your new 494.... |
Triumph_Dave Member Since: 11 Jul 2013 Location: Somerset Posts: 124 |
Having looked at HSE and AB models compared to my previous HSE Black addition, the newer model leather work is not as well put together overall as the older 2103 model. D4 2012 Santorini Black gone RRS 2013 Santorini HSE Black gone MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not. |
Thu Oct 08 2015 1:21pm |
Had this on mine - drove me nuts - its a quick fix that Strastone knew about; brake and accelerator cannot be used at the same time; what was happening is the brake was not releasing once accelerator was pressed; only a split second or two, but enough to make the car do sod all for a couple of secs when trying to pull away at roundabouts etc. They adjusted something on the brake and hey presto- no turbo lag anymore..... Just have to sort the oil leaks now.... [/quote] Thanks for that , looks like the car will have to go back to dealer to check loose rear quarter panels, so i will mention the lag and your experience. D4 2012 Santorini Black gone RRS 2013 Santorini HSE Black gone MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not. |
Thu Oct 08 2015 1:26pm |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 |
Did you get your lag problem sorted Triumph_Dave ? |
Wed Oct 21 2015 11:31pm |
Not yet given to the dealer due to work/travel commitments, but over the last few days it has got better.. I was told on my last model that the system initially "learns" the drivers response, so maybe that has helped, if so its taken 500 miles to do it. Interestingly the "clunk" from the autobox when drive is engaged on 1st morning start up has also stopped??. Would not think its connected though..
Thu Oct 22 2015 2:46pm |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 |
Adam, try some Rainex on your windscreen. Helped lessen my smudge a little. RRS P460e
Thu Oct 29 2015 12:03pm |
Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567 |
Righto! WINNER - 2009 Best in Class Range Rover Sport Award
Tue Nov 03 2015 4:04pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1173 |
having the Bluetooth on means that the music is interrupted all the time when the phone receives a message.
Fri Jun 08 2018 7:08am |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
Thinking about this the things that annoy me are few but ?
Sun Jun 10 2018 11:22pm |
Chips Member Since: 08 Nov 2017 Location: Shropshire Posts: 122 |
For Me on an MY16 A/B
Mon Jun 11 2018 9:42am |
Sounds like the standard non cooling seats are the better option then - mine heat up very quickly and I have to switch them off before they do it automatically because they just get uncomfortably hot. I’ve never found that my bum or lower back gets too sweaty perched on the standard seats. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jun 11 2018 11:41am |
