Home > Maintenance & Modifications > gearbox issues
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
gearbox issues
Need some advice please guys.
I had the cattle grid effect after a double flush at my local iddy on the gearbox and filter change with advanced factors kit problem solved.
15k later its back Big Cry Big Cry
Had a quick chat with inddy and bodsy and hes advised possible torque convertor, or get a mega flush done. Im now thinking mega flush maybe false economy if after the mega flush is happens again.
So now gearbox off time by the looks of things Censored
Can any body recommend a reputable transmission recondition place please or any advise would be greatly appreciated Thumbs Up
Post #477149 Tue Oct 20 2015 2:46pm
Lost for Words
One chance at fresh oil and if it comes back it's time for a new TC, IMO. Been through much the same. Thumbs Up
What mileage(s) are we talking? It may be contained to just a TC if you act quickly, but these things can spread to a full box recon if not done in time. Wink Visiting from DISCO3.CO.UK
Post #477150 Tue Oct 20 2015 2:54pm
Saeedasghar
About 98k mileage wise mate. Im thinking it will cost at the places ive found so far near me £425 inc for mega flush and £950 plus for tc. Cost me less in labour to take the box off then get a flush Shocked for that reason im thinking get it off and over to a gearbox place to give it a going over.
Post #477151 Tue Oct 20 2015 2:58pm
Lost for Words
At 98k, I'd say you have a fair chance of just the TC being required, unless the judder was/is left for a long while (obviously this is subject to no other faults being found etc.). Thumbs Up
£425 is a bit steep for a flush, and the labour to change the TC is significantly more - in fact a power flush only takes an hour or so to complete. About £1-1.5k is right for a new TC in total. For a full box recon (with TC) it'd be more like £2k upwards, dependant on what needs doing. Thumbs Up Visiting from DISCO3.CO.UK
Post #477159 Tue Oct 20 2015 3:17pm
Bodsy
Site Sponsor
Ah now that description is different.....
The cattle grid effect is more usually the mechatronic unit in the gearbox £££££
The torque converter issue is usually symptomised (is that a word......? Wink ) by the revs moving up and down by anywhere between 200 and 500rpm Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #477161 Tue Oct 20 2015 3:20pm
Saeedasghar
Sorry mate in all fairness i wasnt very detailed in the message Whistle
Yeah cattle grid at round about 30mph while on a silight incline for the moment exactly how it started last time before i had the fluid change.
Post #477162 Tue Oct 20 2015 3:30pm
Saeedasghar
The mega flush price is steep but ive rang 3 places and they all seem to be about the same based on ones within localish traveling distance from me that ive found so far Crying or Very sad
Post #477163 Tue Oct 20 2015 3:33pm
Lost for Words
Are the cattle grids different up there? Only I thought the normal TC symptoms, and that that I experienced, was just like a cattle grid effect (and rev surging too)? Confused
EDIT: Are you and the OP meaning more that it's brief, like a cattle grid by that? Idea Visiting from DISCO3.CO.UK
Post #477164 Tue Oct 20 2015 3:38pm
Saeedasghar
Revs during the problem area on the incline seem to be holding as they should guys no change to what it is under normal driving condtions.
Bodsy i assume mechatronic unit is essential a full do over for the gearbox Big Cry
Post #477166 Tue Oct 20 2015 3:42pm
Saeedasghar
Yes mate only brief in certain condtions so far. Manily on a incline around 30mph with steady low revs it feels like going over a cattle grid and when the road levels out or you apply more speed to the engine it stops the grid effect. Sorry if i was vague in the original post.
Post #477168 Tue Oct 20 2015 3:58pm
Lost for Words
That's still sounding just like the normal TC symptoms to me (when I said brief, I was then thinking sub 1 second or something - just an instant blip). It's often referred to as the "cobblestone" or "cattle grid" effect. Will wait for Ian to elaborate. Thumbs Up Visiting from DISCO3.CO.UK
Post #477172 Tue Oct 20 2015 4:30pm
RogerDeFlor
It might be worth having a look at the rear prop shaft center bearing, as that can cause vibration under load, ie up hill at lowish speeds.
It's easy to eliminate, before looking at gearbox rebuilds Thumbs Up
Post #478152 Thu Oct 29 2015 8:02am
Saeedasghar
Thumbs Up Thanks for that will get the garage to have a peek at that when shes in never considered the prop.
Post #478184 Thu Oct 29 2015 1:05pm
