Home > In Car Electronics > how to hardwire into fuse box |
Wilson Member Since: 06 Oct 2015 Location: Ipswich Posts: 78 |
Can anyone point me to a guide or give me basic instructions how to add equipment to the fuse box?
Thu Oct 15 2015 11:10am |
I've used piggyback fuses for years, never had one with an issue if designed as used.
Thu Oct 15 2015 7:51pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Take a look here for information http://www.rrsport.co.uk/forum/topic28640.html?highlight=blackvue Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Oct 15 2015 8:26pm |
Ok, piggy back it is then
Thu Oct 15 2015 9:57pm |
On an 07 it's Mini
Fri Oct 16 2015 7:43am |
Cheers Bodsy |
Fri Oct 16 2015 8:04am |
Lefty65 Member Since: 19 Oct 2015 Location: Corby Posts: 3 |
Bodsy I'm a newbie so can't pm you,but how much do you charge for Bluetooth upgrade,and a totally different question,if I take the fuse out for the DR can I still use the car safely,ie will it still drive normally many thanks lefty 65 |
Mon Oct 19 2015 10:06pm |
Lefty, I'll drop you a message. Bodsys Brake Bible
Mon Oct 19 2015 11:18pm |
I've got all my bits to have a go at this now, just wondered if anyone can advise a good earth on/near the fuse box?
Thu Oct 22 2015 1:38pm |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 |
Open the panel which is part of the bonnet release handle. Behind this panel you will see 3/4 bolts to the chassis with black wires - Any bolt should do the trick. |
Thu Oct 22 2015 1:42pm |
Thanks MNK, I think I know the ones you mean, but I'm talking about the interior fuse box in this case, apologies wasn't very clear. |
Thu Oct 22 2015 1:51pm |
As mentioned above, just means you need to run the neg wire down to it.
Thu Oct 22 2015 2:07pm |
Done it and all working fine... Used the silver screws below the glove box!
Thu Oct 22 2015 8:54pm |
Bodsys Brake Bible
Fri Oct 23 2015 9:17am |
