![]() | Home > General (L494) > SVR Top-Up Oil |
Mark, you may have to preorder some to collect in Germany next time you go for a short drive to the Porsche factory and you'll have to leave space among the cases of wine on the return trip for 15-20 litres of oil as well to hand over to the dealership when the first service is due. It would be interesting to see what would happen in the event of a claim for engine damage if it was found that the dealership had not used the right spec oil as that appears to be the sort of sharp practise that could very easily happen............... and of course they wouldn't put in the diesel's oil and then charge you the exorbitant cost per litre of the right oil, no dealer's workshop would ever do that would they...............? "Sorry sir but we need to keep your car for an extra couple of days as we cannot get the right oil from Land Rover. Would it be OK with you if we put the nearest equivalent in instead? We can assure you that the same oil as the diesels run on can be used in this engine..............." 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 ![]() ![]() |
Oh yes, the dealer will find me much more hands-on than they are probably used to.
And the dealers and car makers wonder why people use nonfranchise garages or specialist independents as soon as the warranty runs out! At work when we get deliveries of lube oils (and we are buying 50,000ltrs at a time and on contract from the oil majors) before it can be used samples of each delivery are collected and sent away for analysis to check that it is as per specification. You might have to start appearing at the service bay with some sample pots and send them back to Castrol for analysis. It would certainly put the clappers up the workshops if a few customers started to take more interest in which oils the dealers service teams were actually putting into the cars 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRS Oli Member Since: 11 Mar 2013 Location: Jersey, Channel Islands Posts: 72 ![]() |
Thanks Mark for bringing this to SVR owners attention, i have as you may know just ordered one which i am told should arrive in February.
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
The 0w20 is primarily used to meet fuel economy and emissions targets. There might be minor variations in formulation for the professional grade - but as pointed out - it is mostly marketing to allow higher profit margins. For top off I would just use regular castrol 0w20 or pretty much any equivalent synthetic. If you are adding less than a quart between changes - the fact that the regular oil is newer than the pro stuff in your sump probably more than offsets any difference in detergents or other additives ... |
