Home > Faults & Fixes > Help needed
Chatty1982
Help needed
Hi just had egr valves blanked off on 2004 hse sport
Came away and there was a whistling sound , driving it this morning really bad whistling sound and no power had to go up to 4000 revs for it to move put still hardly any power
Help help
Post #475631 Wed Oct 07 2015 1:47pm
Disco_Mikey
Split turbo hose Thumbs Up
Post #475634 Wed Oct 07 2015 2:10pm
Chatty1982
It's going back onto the garage,
So could he have caused this problem blanking the egr valves off
Was a really bad whistling noise and no power at all
He said it might be a broken turbo
Post #475638 Wed Oct 07 2015 3:13pm
KKY042
Cyprus
Pls help! I'm new to this forum!
RR sport 2006MY - 2.7 Tdv6, does not start.
Timing belt tensioner fall of its place destroying - the oil pump casing, hydraulic elements and rocker arms of cylinder no 6. Two exhaust valves and one inlet valve of Cyl.6.
Initially, I saw the timing belt and tensioner off & the damage on the oil pump.
I decided to remove the oil pump, and weld the piece of aluminum left from the casing of the pump. This small piece of aluminum was still screwed on the timing belt tensioner. I did so, renewed the timing belt and tensioner and put the engine back to its timing marks, using special tools.
The car started, but a pumping noise from the left bank of cylinders (4,5,6) Was audible, increasing with the rpm. Then I removed the valve cover of the left Cyl head, and found the rocker arms of cyl6 destroyed.
After all I removed the engine and transmission, out of the car - removed the cylinder head (left bank) and replace all parts that needed to be replaced (head gasket, head screws, valve ceals, valves, rocker arms, hydraulic elements and so on. (Almost all of the camshaft mounting brackets, left bank & right bank of cylinders, were loose!!!).
Now, I have everything assembled and put back on the car. Everything seems ok but the car does not start. No fuel pressure in the rails. It seems that the high pressure pump does not work! The delivery pump is working and I have enough fuel coming to the high pressure pump. The fuel pump belt & tensioner also replaced. Strangely the engine was starting 3 days ago, before I removed it from the car. Can the high pressure pump be destroyed some how within 3 days without working??
PLEASE HELP
Post #475642 Wed Oct 07 2015 3:47pm
Disco_Mikey
No, it is fairly common for the hose to split after a faulty EGR has been blanked.
Not sure why this is the case, but I have a few theories, either rightly or wrongly Laughing
Good news is it's a cheap fix Thumbs Up
Post #475645 Wed Oct 07 2015 4:46pm
paupau
England 2007 Range Rover Sport TDV8 HSE Santorini Black
can anyone help me ... im new to this site ..and a lone female who knows nothing abt cars Sad I have a rr sport 3.6 2007 .. yesterday i set off driving and after 5 mins the car felt like it missed a gear , then it came up transmission fault limited gears and lowered suspension locked . i pulled over and turned the car off and then bk on and it seems fine .. then todaywas driving and put my heated seat on and it got really hot and then all the lights on dashboard went off ... arghh please help on any info if you can .. thankyou
Post #477831 Mon Oct 26 2015 10:45am
DerrekL
Hi
can you let me know how you take off the rocker cover drivers side. range rover sport 2007 2.7 v6. I am in the process of stripping it down. Is there a previous guide/link you can send me?
Cheers RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #527274 Wed May 31 2017 7:43pm
