Home > Technical > Tow bar - Thule EuroClassic G6 928
Buster007
I'm looking at buying a Thule EuroClassic G6 928 to carry my bikes. It clamps straight on to a tow bar. I've been told that its not suitable for my detachable tow bar? Has anybody got one of these bike carriers and can confirm if it is suitable to for a detachable tow bar or not?? Thumbs Up Cheers Laurence.
Post #475077 Fri Oct 02 2015 5:45pm
Buckster
I have one similar to what you are looking at, mine is the Land Rover one but made by Thule. Never had any problems using it with a detachable tow bar and can't see why it would not be suitable. Great bit of kit and tilts with bikes on to allow boot access. Just taken this sat at the ferry port Thumbs Up Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #475079 Fri Oct 02 2015 6:01pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Did (whoever it was) explain why it would not be suitable for the detachable tow bar?
I have a Euroway 921 G2 that fits without any problems and has done so for 2 years with plenty of use
Post #475128 Sat Oct 03 2015 9:33am
Buster007
Thanks Buckster for the heads-up. I've changed my mind on the model I'm going for the Thule VeloCompact 925 I think will be similar to yours - which by the way looks cracking on the back of your RRS Thumbs Up Thumbs Up This model seems much easier to store away and can be put in your boot instead of leaving on the back of your car when out for the day and using the bikes! Out of sight, out of mind !!
Paulcp Thanks for your posting Thumbs Up I asked at my local indi LR specialist regarding fitting the electrics for me. When I told him what they were for he told me that the carrier was bolted on to the plate behind the towing ball and not attached to the tow ball. I was pretty sure this was not the case but thought it was worth asking the question before I spent the thick end of 300 then found out he was right Big Cry
I'm having trouble locating one in my area (Southend) Plenty on the internet but I'd like to see one in the flesh (Its a man thing I'm sure?!) Halfords are Thule main distributors, they don't stock this model Sad
Thanks again for all your help guys Thumbs Up
Regarding the electrics will it affect my warranty if I don't get them fitted by LR?? Cheers Laurence.
Post #475133 Sat Oct 03 2015 10:36am
Buckster
I have a big motorcycle chain lock that I attach to the rack and through the bikes via the recovery point on the back of the crossmember to prevent the scum from nicking the rack. A worthwhile investment as I don't fully trust the lock on rack to towbar Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #475139 Sat Oct 03 2015 11:46am
Buster007
Sounds like a great idea - Thanks Thumbs Up Cheers Laurence.
Post #475165 Sat Oct 03 2015 3:37pm
Woppyman
United Kingdom 2012 Range Rover Sport Supercharged Autobiography Siberian Silver
I think I may know the problem. My Thule bike carrier when mounted on detachable towbar is very close to exhaust. This has melted all the plastic wheel retainers. Maybe other tow bars have height adjustment to get higher than exhaust pipes?
 Evoque HSE Dynamic
5.0 Charger MY12
Post #479049 Sat Nov 07 2015 8:01am
Buster007
I did wonder if the tow bar was a little low and that would be a problem with mine? I did a 7hr trip to Scotland from Essex and back then back without any issues Thumbs Up I have the same Thule bike carrier on the back of my SDV6 I think my pipes are set back a bit more under the car Yours seem closer in the picture? I'm very pleased with the bike carrier I also go a cover to go over the bikes which once secured with bungees was perfect for protecting the bike on a long journey Thumbs Up Cheers Laurence.
Post #479055 Sat Nov 07 2015 9:27am
As said above, shouldn't be an issue.
I have the 928 G3 (I think) and oftern run it on the back of our Disc4 with 3 heavy Downhill bikes. I fact,
took it to Morzine in the summer, 1,800 mile round trip and no issues whatsoever. Definitly worth getting a decent lock to go through the bikes/wheels and then the towing eye or even the chassis if you can reach Thumbs Up
 ON THE WAY: BMW F21 M140i
Post #479204 Mon Nov 09 2015 1:05pm
