![]() | Home > In Car Electronics > Sat nav version |
Andypar Member Since: 18 Aug 2013 Location: Milton Keynes Posts: 10 ![]() ![]() |
Can anybody advise what the latest sat nav software / disc version is please |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
2011/2012 I believe 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
WEERAB Member Since: 09 Jan 2014 Location: CANNOCK Posts: 9 ![]() ![]() ![]() |
2014/15 is the latest |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
legal is 2011/12, pirated is 2014 ...note that links to pirated copies is not allowed on the forum.. |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi Guys,
Go into Navigation
Does anybody know the latest version? |
Just updated mine with the 2016 map and sure it changed it from v30.14.02 to v30.15.02 will have a look and check. It also takes nearly 3 hours to update and you need to leave car running all that time otherwise the ignition shuts down and you need to switch it off and on again, although the update continues from the point it shutdown.
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
Yeah and mine's the 5.0L S/C cost almost as much in petrol as the memory stick did. |
On my Audi you just turn the key to position 1 and put the new disc in. If there is a firmware update on the disc it takes a max of half an hour to do it's stuff. Better than leaving your car running half the day lol. |
