Home > In Car Electronics > New Owner- Electronics issue with Central locking and window
adamsd11
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Hi All,
Just purchased myself a 2006 RRS. Love the car but its got a few electronic faults I didnt notice. If anyone could help or advise it would be highly appreciated...
First of all my central locking is a bit all over the shop. When I leave the vehicle and double press the lock key the passenger side front door and drivers side rear door lock however the drivers side front and passenger side rear does not lock? Once the car is locked if I open to drivers door (its opens) and the alarm goes off straight away. Sometimes when I go to lock the Horn sounds? The drivers door does not lock from the central locking button on the dash however if I use the small area on the handle the door will lock so Im presuming it must be electrical? Have no idea whats going on, I presume this could be an actuator of some sort but wondered if anyone could confirm?
Secondly the rear passenger side door (NSR) it appears like all electrics do not work on the door... The lock has to be manually pressed like the drivers side and the window will not work from the switch on the door card however it will work if accessed by the drivers main switch for all windows?
Not sure if this is a common fault or an expensive one, I wanted to know if there was a quick fix before I take the door cards off for further investigation.
Thanks all,
Adam
Post #473730 Mon Sep 21 2015 10:02am
DrRob
Bodsy can probably fix that........ Whistle Visitor from fullfatrr.com
Post #473739 Mon Sep 21 2015 12:54pm
adamsd11
Sorry mate, new here... Whats Bodsy?
thanks
Post #473881 Tue Sep 22 2015 1:02pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Bodsy !!!!!!!! We know him as GOD Bow down him and Disco Mikey are the GURUS of Range Rovers
Post #473893 Tue Sep 22 2015 3:24pm
SRE
Spain
Plus Geoff , Flack & Disco Mikey. Lots of posts ref these guys on the Disco 3 Forum In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #473900 Tue Sep 22 2015 4:16pm
adamsd11
Ah right thanks all! Smile
Post #477374 Thu Oct 22 2015 9:47am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Hi, I seem to have the same problem with the drivers door on my 2006 RRs S/C. Sad
Which means that thieves can get into it - they did Mad so I am looking for the solution.
If you know the answer Question it would be great as we downunder don't have many experts. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #508885 Sat Oct 29 2016 3:19am
adameverett
sounds like faulty driver door actuator, common fault they fail. Blip the car and door just opens on the handle. You end up double checking it every time you leave it in risky areas.
Post #508891 Sat Oct 29 2016 8:30am
