![]() | Home > Orders (L494) > SVR Ordered! |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 ![]() ![]() ![]() |
YUM!!!
DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283 ![]() ![]() |
You're right Phil, whilst I can't comment on the popularity of the bespoke builds, we haven't done a 1000..... |
Not what Rob told me when he was on the system 2 days ago😳 None currently
rich1231 Member Since: 30 Oct 2005 Location: Essex Posts: 24 ![]() |
I believe my car is about to enter build |
Dickie Member Since: 27 Mar 2013 Location: Hampshire Posts: 200 ![]() ![]() |
Well as another lucky chap soon takes delivery of their SVR, I'm now bowing out.
why did you sell it so quickly? |
Mainly as I've just moved house to the other side of the country with work and because I would be putting on far more miles than the 8000 I've done in the last 5 months thought it better to not keep pouring even more money into the fuel tank!
Aloha Member Since: 12 Sep 2015 Location: Europe Posts: 10 ![]() |
Trying to decide between the 5.0 ATB and the SVR and am looking for some input |
Aloha,
Anyone found a non LR source for the oil for SVR's? |
Thanks Dickie ![]() Lots to think about...., my wife also found it noisy when cruising (she called it "droning", with the flaps closed also, allthough a lot less) Good point about the depreciation, even worse here because most buyers prefer the diesels. Was your Supercharged "clunky/loose" when hitting speedbumps etc ? I really noticed that when driving the SDv6, the SVR was miles better (my TDv6 is somewhere inbetween) No Supercharged(demo) is available here for me to compare (NL) and the lack of "looseness" is probably the biggest reason for me to choose the SVR over the Supercharged besides the sound lol (My wife thinks Im crazy) |
To answer your questions: There is obviously a difference in weight for the panoramic roof with a small increase when going sliding roof but the ARC system and suspension are tuned to accommodate this. We worked hard on chassis set up in order to match the ride quality of the standard car - the SVR is a Range Rover after all! I can't comment on the fit and finish. However, the SVR has different subframe bushes and a different ARC map to the standard cars. The SVRs are signed off on both 21" wheels as standard with the optional 22"s included in the chassis control maps. The 22"s are a more tarmac focussed tyre but still hugely capable off road. The Conti CS5's are pretty epic in the wet; you should have no concerns here. Feel free to PM me if you have specific questions you want answering ![]() |
Thanks for the explanation DaveW |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
"They wanted the SVR to have even more power on snow"
