Home > General > Front Propshaft
rayc59
United Kingdom 2006 Range Rover Sport TDV6 Bonatti Grey
Front Propshaft
Ok lads looking for some help here as i have googled this to death and also asked on other forums but getting nowhere my front prop shaft going into the diff is really badly grinding and no reverse drive, is this a easy fix with new prop. the vehicle is a 2006 sport auto with 74k on the clock i have already done new air compressor two front wheel bearings new disks all round, new rear brake caliper 4 new tyres and its starting to get me down it does not lead a hard life as i work offshore so i only drive it two weeks a month
Crying or Very sad Crying or Very sad Crying or Very sad
Post #472898 Sat Sep 12 2015 5:51pm
Disco_Mikey
Ray, I have never had a failure like that in 10 years Confused
Have you had the covers off and physically checked it?
Post #472901 Sat Sep 12 2015 5:57pm
rayc59
thought it was the driver side drive shaft but when i jacked it up and turned the wheel by hand the noise was coming from underneath so after going under for a look the prop bit that goes into diff is mangled
Post #472930 Sat Sep 12 2015 8:58pm
Disco_Mikey
The good news is, it is an easy fix.
No idea how it has failed though. At least it was easy enough to diagnose Thumbs Up
Post #472931 Sat Sep 12 2015 9:01pm
rayc59
Cheers Mike so do you think i should just buy a new prop and put it on then
Post #472933 Sat Sep 12 2015 9:07pm
Disco_Mikey
It sounds like it needs a new prop regardless, but just give it a look over to see if ere are any indications of why it failed...
Post #472937 Sat Sep 12 2015 9:19pm
Disco_Mikey
Looks like the diff has collapsed Shocked
Post #473470 Fri Sep 18 2015 7:25am
rayc59
Trust it to be my sport, just my kind of luck Big Cry
Post #473494 Fri Sep 18 2015 11:16am
Bodsy
Site Sponsor
Oooo that's a bit nasty! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #473731 Mon Sep 21 2015 10:06am
rayc59
Post #473805 Mon Sep 21 2015 8:16pm
Disco_Mikey
That was one Censored diff Ray Shocked
Post #473810 Mon Sep 21 2015 8:23pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
OOOH! I love jigsaws
Post #473811 Mon Sep 21 2015 8:25pm
rayc59
Thanks for fixing the problem so quick Mike, think I will have to stay offshore to avoid the wife after she had to raid her piggy bank lol, I cant understand why such a nice vehicle with a long 4x4 history can do this to a diff when it only has 74 K on the clock glad I was not in the Sahara Big Cry Big Cry Big Cry
Post #473913 Tue Sep 22 2015 6:18pm
Disco_Mikey
It looks as ough someone has had something to do with the diff at some point in its life
The axle tube had been revealed with something other than what LR use, as well as the bolt for the tube mounting having being fitted the wrong way
It's almost as though the diff had been run without oil, though there was still a very small dribble in the bottom of the diff casing...
Post #473927 Tue Sep 22 2015 8:09pm
