![]() | Home > General > LED main |
Not RRS related, I have just had the stage coach one candle powered Halogens on my Defender replaced with a set of full on LED sealed unit headlights that are guaranteed waterproof, CE compliant etc etc. The difference driving at night compared to before is, well there is no comparison, like night and day!! The other advantange is that their power consumption is a lot less so hopefully no more problems with headlight wiring on a 20 year old vehicle 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Hi Tim, I,ve been thinking about doing the same with my 90, though do have uprated bulbs fitted which are pretty good. I carn,t think of the brand now though. 2008 G4 RRSport TDV8 current
My electrical knowledge extended to continually changing the dipped beam lamp that blew every time we had damp weather...... the local Indy (Lix Toll Land Rovers) suggested I try them as a "fix" for the lamp blowing episodes every winter. Linked into the light problem was that when the offside dipped beam blew I also lost the horn! Now I have dipped beam, horn and great range on the headlights........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
The issue of with LED as a replacement for standard bulbs is the positioning of the light source. The reflector and lens are designed for a point source (the small hot bit in the bulb). LEDs tend to produce light from a large number of points spread over a large area. The result is that the light doesn't hit the reflector at the correct angles and so isn't directed forwards from the unit correctly. The Defender replacement units will have been designed from the start to use large LEDs. 2012 SDV6 - it's missing a couple of cylinders
As RRSTDV8 has pointed out, an LED retro fit would require light to be emmited from the exact spot as the halogen filament. Aside from this, LED are not such a precise light source and this makes them much harder to focus from the start. This is why an LED spot/pencil beam just can't deliver.
Thanks guys, guess I'll leave it as it is.. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4454 ![]() ![]() ![]() |
I have found Osram Nightbreakers to be the "whitest" bulb with decent output
I use the Nightbreakers in my H7 units too. They are a very similar colour to the HID bulbs. |
